DefaultSettingEXE MFC Application has stopped working
6
Everytime I turned on my vista laptop a message prompt displays "DefaultSettingEXE MFC Application has stopped working". How do i fix this problem?
    Acer Aspire 4920
    Intel Core 2 Duo T5550 1.83GHz
    2.0 GB
    Mobile Intel 965 Express Chipset Family
    SATA
3,375
Hello,
I am willing to help you with this problem.
If at any point I say stuff too complex, just slow down and ask :)
SAFE MODE:
Please boot into Safe Mode and tell me if the problem remains. Turn off computer, switch on, immediately start tapping the F8 key, until you get a screen where you can use the arrow keys and Enter to select Safe Mode with Networking.
WEBCAM:
Do you have a webcam, and if so, what model?
CRASH DATA:
1. Click on the Start Orb and then click on Control Panel. (All steps have screenshots below and you can click on any screenshot to enlarge it.)
2. Double click on "Problem Reports and Solutions".
3. Click "See Problems to Check" on the left hand pane. (N.B. Your window will not look exactly the same as mine)
4. Under DefaultSettingEXE MFC, click "More Details". I do not have DefaultSettingEXE MFC in my list, so substitute my Installer for your DefaultSettingEXE MFC.
5. Copy everything in the red box on MY screenshot and paste it into a reply to this thread. Alternatively you could make a screengrab of the whole window and reply with that instead.
How to take a screengrab: How to use the Snipping Tool in Vista
6. Click "OK".
7. Check "Select All" and "Check again for solutions to other problems" then click "Check for Solutions". If any new solutions are found, particularly for DefaultSettingEXE MFC, open them up and see what they say.
Thanks,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
6
Thank you Sir. But Mm snipping tool seemed not working also. Huhuhu!
    Acer Aspire 4920
    2.0 GB
    SATA
3,375
Don't worry, there is only one line that is important at the moment. You see on my screenshot, Problem Signature 1, I need to you copy here the file name afterwards, in my screenshot, installer.exe. Can you please write down the .exe name in your report?
Thanks!
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
