defrag progress graph
13
Hi. Does anyone know why there is no defrag progress graph in vista (like the one there was in xp). The defrag just has a scheduler or defrag now and then there is no way of knowing how far along it is. Any thoughts would be welcome. Thanks.
Fumz
Buggin
878
Location
California
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Everlong
To xor or not to xor
1,317
Location
Lancaster University, England.
I use Auslogics and it works great. Nice and light too.
Used to use Diskeeper, but I'm sure that messed my hard drive up causing me to format every 2 months or so.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
DiskeeperRep
Diskeeper Support
Vista Pro
12
There is no drive map/GUI for Vista defrag. However, you can get verbose analysis report as well as additional defrag options from the command prompt (run as admin).
Also, when defragmenting Vista (which has the shadow copy service active), with a third party utility it's advisable to use the VSS compatible defrag mode to minimize unnecessary shadow copy activity.
Shadow copies may be lost when you defragment a volume
Hi Everlong,
Which version of Diskeeper did you use, and with what OS? What was the specific problem that you encountered?
Best regards
Representative
Diskeeper Corporation
Everlong
1,317
Location
DiskeeperRep said:
Hi Everlong,
Best regards
Representative
Well it was one of a few causes possibly, over exaggerated a bit. Can't remember which version I used, it was the $50 one though. The main problem being with the boot-up defrag on Vista 32 bit. I usually just chose to run chkdsk with the defrag (as you have to choose either page file defrag or chkdsk to run) and chkdsk ran first then restarted the PC.
Everytime the PC restarted and Vista started, it would never get past the loading screen, so I just used to do a cold reboot and Vista would load and do the Diskeeper defrag and load normally, but then I would keep getting a message once on the desktop saying the file system was corrupt and to run chkdsk.
Though the hard drive I was using then died soon eventually, and with my new hard drives, I just started using Auslogic's defragger.
    ASUS Xonar DX
    100Mbps
