Deleted email not going to Recycle bin
148
Location
Japan
Windows:vista home premium 32(Japanese), Email: windows email.
I have noticed recently my deleted emails are not going in to Deleted Folder.
I have also confirmed by Right clicking on Recycle Bin that
"Do not move files to the Recycle Bin.
Remove files immediately when deleted" is not chosen.
Any help will be appreciated.
I have read answers in the forum but did not find suitable one.
Thank you
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
If you go to delted items (Tree showing various folders) and right click and go to proeprties, do you see Deleted Items with an icon of the recycle bin?
148
Location
Japan
Thank you for reply.
On left side in windows e mail there are folder and among them is TRASH folder where deleted items goes. I clicked on that as you said, clicked properties, I can see Bin but empty.
Just now I did an experiment.
I cleaned un wanted mail folder(not Trash folder) so there was nothing left in trash folder or unwanted mail folder. I deleted on email which I did not needed. I landed in to the trash bin which showed in figure 1 and disappeared as I am typing this message.
Please refer attached screen shot.
Thank you
richc46
Staff member
20,105
Location
Deleted mail folder and recycle bin are not the same
Your email sounds like its corrupted. You may want to download and try the most current, Windows Live Mail 2011
I have a hunch. Try with a clean boot.
http://support.microsoft.com/kb/929135
Bet its your maintenance software, or maybe antivirus
For further information that mail does not go to recycle bin, it goes to deleted mail folder. This is not a bin problem.
EDIT From the email client you have to set up send deleted mail to deleted items folder
Are you using pop3 or Imap settings?
Is your folder set up to handle large emails?
Did you check settings?
Tools > Options > Advanced > Maintainance> tick 'Empty messages from Deleted Items folder on exit > Close
148
Location
Japan
Hi, thanks for reply(my answer is in Blue Italic)
oK thanks
Yes I know Live Mail but not sure if it is ok or not, I mean I used to Windows mail that is not using Microsoft mail.
If I will try what will happen?
What are steps?
I gues I am using Pop3
I think more than 1 GB
Attaching screen shot. Sorry everything is Japanese
Thank you very much
richc46
Staff member
20,105
Location
What are steps?
Thank you very much
Clean boot will allow you to boot with out the startup programs, no anti virus etc. When you set up clean boot you will see the programs that you will affect.
I think on windows mail these are the steps
Tools > Options > Advanced > Maintainance> do not tick 'Empty messages from Deleted Items folder on exit > Close
I have windows mail 2011 so cant check.
If you want to take a chance with another email client that would be up to you.
I think that if you try a clean boot next, the problem may be solved. After the clean boot, its easy to set it back the way it was.
richc46
Staff member
20,105
Location
#8
It sounds like some software you have is deleting that mail. Try the clean boot. If you dont understand something, just ask.
148
Location
Japan
#9
I thought I found the reason I appled the procedure to clear all stuck messages in the deleted folder, http://www.vistax64.com/tutorials/62560-windows-mail-problems.html
It cleared all stucked messages as you can also seen in my previous screen shot saying what are these. But while typing this message I deleted some emials they went in to the Deleted Folder and later disappeared.
Could it be my Norton Internet security?
Question: what will clean boot do if I install?
Thank you
richc46
Staff member
20,105
Location
#10
All clean boot does is it does not permit other software to load up at start up.
For example there will be no anti virus, no fire wall, and many other programs. If the problem is not fixed, you merely check all the start up programs again, and you are back to normal. If the problem is fixed you check a few at a time to see which one caused the problem
148
Location
Japan
#11
Sorry I was not aware of that middle button. but I did it now.
Ok so clean boot will stop other program at start. It means I have to know which programs are checked in start up if needed later I can use them.
Thank you
richc46
Staff member
20,105
Location
#12
Folllow the instructions. When you go to msconfig, you will see a lot of programs with checks next to them. When you want to put the programs back, just check them again. If you follow the instuctions carefully it will be easy and no problems. Understand everything that you are doing step, by step. Ask if you need to.
richc46
Staff member
20,105
Location
#13
I read your question again. Let me explain this. Clean boot is only a test. It lets us find out which program is causing the problem. Once we know that we fix it and you go back to normal boot and you will be just like you were before the test.
148
Location
Japan
#14
Hello,
This morning, when I was about to follow your instructions I have noticed 42 deleted emails were in the Deleted Folder and also in Purge Folder(if this term is ok)20 emails.(refer attched screen shots)
As I said in my previous posts, I put cursor on Deleted folder then deleted.
As you can once again see in the screen shot there were more than 2000 stucked email which I was not aware of.(refer attached screen shots)could be the cause of problem.
I am sharing this because who knows may be some one need help.
Once again thank you for best help.
