Deleted HDD Recovery Partition By Mistake
petbro
Hi All,
I deleted in error the pre-installed HDD Recovery partition. I have the Recovery disks which I made when I first got my laptop so I just need to know if its just a case of copying the files from the disc back to the HDD Recovery Drive? Or do i need to do a complete new re-install from the disks?
Thanks
    Toshiba Satellite L300D-13S
    AMD Turion(tm) X2 Dual-Core Mobile RM-70 2.00 GHz
Ex_Brit
If you're going through hell, keep going
I doubt it very much. Those discs simply address and draw on the files that were on the recovery partition itself. I know my system recovery discs no longer were of any use after I deleted the recovery partition and merged it with my main one as I no longer needed it anyway.
You would have to check with whomever provided the system.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
petbro
Thanks guys. All sorted. My recovery disks did the job. Never had to do a recovery before, but glad the first thing i did almost 8 years ago was to create the disks.
Thanks again.
Ex_Brit
Glad it's sorted out ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
SIW2
8years, wow. You must have a lot of updates. Good thing you made them though.
Best thing now is to make an image. Free versions of Aomei Backupper or macrium will do the job.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
