Vistuser64
I have found Vista forums very useful in the past. This is the first time I post so hope I am doing it right.
I recently reinstalled my 64 bit Vista OS, including 64 bit SP 1 & 2 (which I also saved to an USB drive). Everything seems to work okay except for the Dell Laser 1100 printer. I have been unable to reinstall the driver from the Dell disc which had worked before. The Dell disc goes looking for newer drivers but the installation fails. Windows updates has a Dell update, but this also fails to install.
I have gone to the Dell website and downloaded other 64 bit drivers, but those also failed to install.
Error messages display : Windows can't install DLP 11 kernel-mode printer driver...
OR
….Printer driver not compatible iwth policy on your computer that block NT4.O drivers.
Now, I have looked the SP 1 & 2 files on the USB drive, and there is a compatibility mode listed but I did not make any selection before installing. I was not even aware of that.
I have tried to uninstall the services packs as per MS instructions so I could make a compatibility choice but am unsure which one it should be – Win NT4, winserver 2003?
How to uninstall Windows Vista service packs as a troubleshooting step
but the packs are not listed. They are definitely installed, as I tried a reinstall, and was told they were already there.
Would anyone have any idea what else I could try?
Thanks
OR
Thanks
- generic
- Intel xenon
- EVGA nForce 650i ultra
- Graphics Card(s)
- ATI Radeon HD 2600 pro
- HP x2301
- Seagate, WDC
- MS ergonomic 4000
- MS
