I have a Dell XPS 420 that requires a new cell battery, CR2032.
The links said to record my BIOS settings first and to reinstall those settings after I reinstall the battery.
Jerry
1/30/2023
- What happens if after I replace the battery, I do not change any F2 settings and use the default settings which will occur after I replace the battery. Is the default option okay to use?
- If I select F2 (Dell System), there are 14 fields I can select. What field do I choose under F2 to record and/or change the settings? I use Vista.
Jerry
1/30/2023
