Solved DEP exceptions- where are they held?
dal987
Hi, recently 'something' deleted my DEP exceptions. I've not seen that happen for a long time. Then it happened again. I even suspected a ccleaner upgrade (hmm, surely not!).
Anyway, given that, do you know where they are held? Or how to back them up?
I tried regshot, before and after adding one, but it found nothing. (Compares registry snapshots).
Searched for DEP exceptions/back up/ backup/ location etc etc...
Thanks!
    AMD Athlon X2
    3Gb
    500Gb 7200RPM
    Laptop HPG60
Hi, I can finally answer my own question:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
appears to be where the list is recorded.
Using Process Monitor with careful filtering, after several attempts, a list of exactly the exe's recorded as exceptions appears here.
    AMD Athlon X2
    3Gb
    500Gb 7200RPM
    Laptop HPG60
