Desktop icon does not delete
veeseekay
1
Hi folks,
I have an icon on my desktop which refuses to get deleted.
I have gone looked at various other posts and have tried to follow the steps..unfortunately none of them have helped me get rid of the sticky icon.
the file name is RATATO~1.rm and i dont know how it was created.
* deleting in safe mode doesnt help.
* tried shedding the file wid mcafee...doesnt work.
* deleting from cmd prompt doesnt delete.
* have tried to remove the registry entry, there are various entries and am not able to figure out the exact entry.
When i try to delete, the delete program goes into an infinite loop.
says " recycling 1 item..calculating time remaining" and gets stuck.
please help!
thanks
~v
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
Hello VeeseeKay,
Since you have the 32 bit Vista, you might see if using the free program Unlocker will allow you to delete it.
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
delta7
1
Hey! Just thought Id mention I had exactly the same problem with a .rm file (Real Player) that would not delete off the desktop. The Unlocker Assistant worked brilliantly, stopped EXPLORER.EXE using the file and deleted it!
