Solved Desktop Icon font color change
ronspruell
I need to know how to change the font color from white to black. I clicked on personlize then went to windows color and apperance then Icon but the color change was grayed out. Anyone that knows a work around I really need it. Right now the font color is white but the background I want to use is light which makes the fonts type hard to read when it is white. Changing to black would make all the difference in the world.
Ron Spruell Sr.
Brink
Staff member
mvp
Hi Ron,
I do not think you can unless you switch to the Windows Classic color scheme.
This might work as an alternative for you though. In the Visual Effects Performance Options, check Use drop shadows for icon labels on the desktop. This should help make them easier to see.
http://www.vistax64.com/tutorials/75417-visual-effects-options.html
  • Show second system?
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
Brink
Staff member
mvp
I had almost all of the check boxes unchecked to speed my system up. I did not have transparent unchecked but I did uncheck it and the box for color change on the icons is still grayed out. Microsoft has a long way to go yet. There should be a way to change the font color since they know the background would be changed by users. All I want right now and I did say now is a way to change the font color from white to black even if I have to edit the registry. If this be the Case I will need to know where and what to put in to change the font color. Maybe in the next upgrade or update they will add this little nicety.
Thanks for the help thou.
Ron Spruell Sr.
Ron,
I found this free little program D-Color XP 1.2 that will you change the desktop icon text or background to whatever color you want them all to be. It was made for XP, but I tested it and it works fine on Vista 32 bit and 64 bit. After you install it and run it, you will see a tray icon. Click on it to change the colors.
Dindo Liboon's Website
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
ronspruell
Thanks Shawn, if nothing else turns up I will give it a try. I just had so much trouble getting upgraded from primium vista to ultimate I really would hate to mess things up.<BG>
Ron Spruell Sr.
Brink
Staff member
mvp
LOL, I can understand that. So far I had no problems with it if it helps.
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
Robert Runyon
Shawn,
I just wanted to thank you for your advice on the desktop font color change for Vista. I used the program and now can actually see the names of all my icons. My desktop changes daily (I know a resource eater, but I like having a new image greeting me everyday), and many have white or very light backgrounds. Now if a background comes up that matches the color I chose its a simple click and its changed. Thanks Again.;)
Bob
Brink
Staff member
mvp
You're welcome Bob, and welcome to Vista Forums. :party:
I'm glad to hear that program helped you.
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
yonni
There is actually a trick whereby you can do this. The thing is to change the "colour" of your desktop background (the colour it would show if you're not showing a picture on it)
The easiest way I know to do this is by using firefox (not tried it with other browsers). Basically, open up the image you want to use in firefox (I find all of my desktop backgrounds on the internet anyway), then right click on it and select "Set as desktop background". On the dialog that then shows, choose between Stretch/Tile/Centre and then on the top right there's a selector marked "Colour"
Set this to the colour that MOST RESEMBLES your background, not that which you'd like your text to come up with. So, if you have a dark background, set it to black, if you have a light background then set it to white.
Vista will then change the colour of your icon text accordingly. If you set "Colour" to white, then the text will appear black, and vice versa.
I just tried setting "Colour" to red and the text has stayed white, so maybe this trick will only work for changing the colour from black to white and vice versa. But at least now you can choose a little :)
rebdk
Go to Control Panel > Personalization > Desktop Background and click "Change background color" which is at the buttom of that screen.. There you should pick white if you want black text and black for white text.. Sorry if anyone mentioned this before me lol im to lazy to read thru the topic..
Have fun..
Scooter415
This will work, but its kind of quirky.
1- Right Click on your desktop and goto Personalize
2- Click on Desktop Background
3- In the location field select "Solid Colors"
4- If you want "Black" text choose the "white" solid color background
5- If you want "White" text choose a "black" background
6- In the location field select "Windows Wallpapers"
7- Choose the Wallpaper you want
8- Your Text should stay the same color it was when you chose you background color in steps 4 or 5.
9- Apply your background changes.
Yes, this is quirky, but it works. Well, at least it works with my Vista Business Setup.
I agree that there should be a place to do this setting and can't believe that Microsoft forgot to let us make a Font Color Setting for the Desktop... I'm sure they will fix it eventually...
Hoping this helps ya all...
Scooter
  • Name
    Scooter
    Many systems... Self Built Intel System, Dell Latitude Laptop - Main Systems
    3.2 Ghz Hyperthread - Dual Processor in Server System
    Intel all the way
    4 GB in PC - 16 GB in Server
    So many can't remember all of them now
    Integrated Mother Board Graphics
    I love my Sony Bravia LCD HD TV hook up - 40" Screen
    1280 x 1024 on Bravia
    I Love my Raptor Drives in Raid 0. Fastest ever... Many other drives SATA, and lots of external USB Drives... Over 10 TB in total...
    Antec Cases Rock
    Lots of fans...
    MS Wireless Laser 5000, have another MS Wireless Also
    Microsoft Natrual, and MS Wireless Comfort 4000
    Not fast enough! North MN doesn't have a lot to offer 512
    Occupation
    Business Analyst - IT (Oracle, but learning more a
    Working on MS Certifications. Love the Microsoft Action Pack. Access to lots of software to play with is great. Working on doing more with Hyper-V and Virtualization. Need to spend more time on my web-site. Haven't had the time lately. 10 Computer Network. Xbox 360 Media Center is great. Sony Blue Ray is awesome - Wonder how this BD Live stuff is going to work out. Glad I picked BlueRay w
    Country Flag
    usa
    State/Region Flag
    us minnesota
TrillianK
So glad you posted on this, I was having the same issue. Of all the things to not let users control, the font colour on their desktop..fail :) Thanks for the info guys!
    Toshiba
    Intel Pentium Dual CPU T3200 @ 2.00 GHz
    2.00 GB
    Laptop
Imperfect1
Shawn,
My desktop changes daily (I know a resource eater, but I like having a new image greeting me everyday), and many have white or very light backgrounds. Bob
Apologies for being OT, but Robert, what application or setting are you using to change your Desktop daily? I would love to be able to do that!
  • Name
    Sue
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
    Occupation
    Professional
    Country Flag
    usa
cozezien
Thanks for all the advice from everyone regarding fixing this. I found the easiest way to get the background colour changed is to goto:
Control Panel -> Personalization -> Window Color and appearance -> Advanced -> item: desktop color 1 (I set it to white)
Hope this helps other people.
dylana
Ron Spruell Sr.
Ron,
wow thanks for this little program. im using vista 32bit as well . and it works fine too
time88
Hello my apologies, missed a step in the previous msg. Pls see below.
You can customise your desktop fonts, colours etc by doing the following:
1. Right click your desktop and select "Personalization"
2. Click on "Window Color and Appearance"
3. Scroll down and click on "Open classic appearance properties for more color options"
4. Click on "Advanced".
5. Now, say you want to change the font color of your desktop icon, click the tab and scroll to the word "icon". Then you can change the font colour, type etc. using the colour palettes.
Regards,
Time88
  • Name
    Time88
camzy
I download D-Color XP 1.2, and nothing is happening. I have installed and run the program, set icon colours, and still nothing, not a single change. Im not sure what im doing wrong, and am following all the steps. Could you please help me, as i too have icons that are hard to read.
Regards Cameron
  • Name
    Cameron
    Country Flag
    australia
    State/Region Flag
    au new south wales
Imperfect1
Regards,
Time88
Actually, when you go to Icon, you can change everything EXCEPT the color of the font. You can change the icon size, font type, and font size, but NOT the font color.
  • Name
    Sue
    1680 x 1050
    built in - HP
    max
    Occupation
    Professional
    Country Flag
    usa
currysteph
THANKS rebdk.....your suggestion was perfect and solved the issue without having to install anything or tweak the registry. :D
  • Name
    Steph
    Dell XPS M1710 Laptop
    Centrino Core Duo 2Ghz
    4Gb
    nVidia GoForce 7950 GTX 512M
    SB Compatible
    1920x1200
    B: 25G
    C: 200G
    E: 250G
    K: 200G
    M: 200G
    S: 350G
    T: 2000G
    V: 1000G
    W: 25G
    Microsoft Optical Wireless 4000
    6M
    Occupation
    Teacher
    Country Flag
    usa
    State/Region Flag
    us texas
