Desktop, icons, everything suddenly too big
WorkrszR
I have only had my computer for about 2 months now and it has always worked fine with my monitor. The other day I set the computer to sleep and went to walk out of the room I turned around and it was back on and the desktop, icons, firefox etc. all look big and stretched out. I have played around with the resolution but that really only mildly helps and is not the prob.
Any help would be great im not all that great when it comes to computers and dont know where to start. The monitor is a 20" Sceptre lcd. computer is a ZT Systems with Integrated Intel GMA3100 Graphics
Brink
Staff member
mvp
Hello WorkrszR, and welcome to Vista Forums.
You might also check to make sure that you DPI is still set to the default of 96 dpi. If that is not it either, then see reinstalling or updating your video driver may help.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
WorkrszR
Hmm I tryed looking at the DPI and it was set to 96 then I went on the intel site and downloaded/installed the graphics driver and restarted the computer but it still looks the same.
archie123
I Tunes hates Me
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
WorkrszR
Do you think that would help? in my situation it looks like every thing is stretched even pictures when im on the internet not just the icons :(
Fastboy42
Banned
Try holding in CTRL and using the scroll wheel
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
archie123
I Tunes hates Me
oh sorry i didnt realis it was all stretched , no then mate it wont help , could you post a screenie of your issue , your monitors default res and frequency and your current res and freq setting setting
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
stoneys-nutz
Gamerholic
Why not just try a system restore to a point before this started happening.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
WorkrszR
Ctrl+scroll wheel only effects the internet etc. not my actual desk top. Even messing with it or resolution it seems like every thing is stretched to the right maybe.
I tried a system restore earlier..........4 times to different restore points......good to know that doesn't work. I keep getting a message saying that "An unspecified error occured during system restore" and that my files and settings were unchanged.
I have also ran a complete scan on the machine with my Norton anti virus and also adaware and malware removers.
Resolution is set at 1024x768 and refresh is at 60hertz, im not sure what the monitors default is.
Fastboy42
Banned
Screenshot please. Help us Help you
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
archie123
I Tunes hates Me
is this it?? Newegg.com - SCEPTRE X20WG-1080P Black 20.1" 5ms(GTG) Widescreen LCD Monitor 300 cd/m2 1000:1 Built in Speakers - LCD Monitors
if so your res wants to be 1680x1050 75hz (if it fails and it says "out of range" dont worry itll reset itself after 15 seconds if this happens set the freq to 60hz somemonitors need a little tweaking in the graphics roperties to run 75hz but definately try that fist 75hz is better)
If this doesnt help im thinking its your monitor settings not your pc
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
DSAngal
FWIW, and for those who arrive here in the future with the same problem: THIS WORKED for me. In my case, everything was fine when I looked away from my desktop, then when I looked back the icons were huge. I must have accidentally and unknowingly held Ctrl while turning the mouse scroll wheel at some point when I wasn’t looking. (This isn’t an unlikely scenario for me.) Consciously using the Ctrl + scroll wheel combination gave me the "control" to fix the problem -- in fact, I can set the icons to a selection of sizes now.
This solution works, or at least it did in my situation. LSNED.
    Microsoft Surface Pro 3 128GB
    Intel Core i5-4300U @ 1.90GHz / 2.50GHz
    Microsoft proprietary
    8x Micron 2LEI2 D9PXV for a total of 4 GB RAM
    Intel HD Graphics 4400 (integrated)
    Dolby audio-enhanced (integrated)
    12" ClearType Full HD (tablet)
    2160 x 1440
    128GB SSD and 64GB microSDXC Class 10 UHS-1 Memory Card
    Escalade 42 Wh, 7.4 V, 5676 mAh battery, ext. 36-watt PS
    Magnesium tablet
    Dual micro fans
    Börnd 1000/2000 DPI Bluetooth 3.0 optical wireless mouse
    Microsoft detachable keyboard (magnetic)
    40 Mbps DSL
    802.11ac/802.11a/b/g/n, Bluetooth 4.0 Low Energy, 5MP and 1080p HD front- and rear-facing cameras, mini DisplayPort, full-size USB 3.0, microSD card reader, headphone jack, ambient light sensor, accelerometer, gyroscope, magnetometer
