Solved Desktop icons overlayed with another icon
julzee
Pittsburgh
Posts
4
I installed Adobe Acrobat 9 Pro Extended Trial version. As soon as the install finished I noticed that every single one of my desktop shortcut icons now have another icon overlaid in front of them. It's the white square icon you get when your shortcut is not linked to it's program. But my shortcuts are linked and work. Everything's normal about them except for this overlay.
It even appears in front of new shortcuts I create.
Uninstalling the Adobe program did not get rid of them.
Does any one know how to get rid of these overlays...?
I'm running Vista Home Premium SP1 x64
    Compaq Presario CQ60 Notebook PC
    AMD Athlon Dual-Core QL-62
    Wistron
    4Gb
    NVIDIA GeForce 8200M G
    Conexant High Definition SmartAudio 221
    1024 x 768 x 4294967296 colors
    TOSHIBA MK2552GSX ATA 250Gb
mansrm81
Rockford, IL
Posts
1,884
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
julzee
Pittsburgh
Posts
4
Thanks for the reply. I'll try your suggestion but it's not shortcut arrows that I've got the problem with. I already had the arrows removed using Ultimate Windows Tweaker for Vista before I installed Adobe. But maybe this will work..?
I'll let you know how it turns out.
    Wistron
    4Gb
julzee
Pittsburgh
Posts
4
It's fixed! Thank you so much mansrm81...:)
When you linked me to how to remove the shortcut arrows it got me thinking. I had forgotten that I had already gotten rid of the arrows with Ultimate Tweak so before I tried your links, I opened up UT and unticked 'remove shortcut arrows' then logged off/on. This replaced the Adobe icons with the arrows. Then I re-ticked 'remove shortcut arrows', logged off again and everything's back to normal.....:)
Those icons were driving me crazy! Thanks for helping me out here. I couldn't find any solutions on the web. You rock!
    Wistron
    4Gb
mansrm81
Rockford, IL
Posts
1,884
Your welcome julzee also welcome to the forum too.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
julzee
Pittsburgh
Posts
4
Thanks. I hadn't planned to become a part of this forum but I'm glad I signed up. I'm still trying to get used to Vista after buying this laptop. Not that bad of a culture shock after XP but still confusing at times. I'm still trying to figure out what the difference will be between 32 and 64 bit.
I think I'll find all the help I'll need here.....:)
    Wistron
    4Gb
mohdar
Posts
1
I just created an account to thank both of you guys for the great tips. I had a very similar problem and could not get my desktop icons to work. But after seeing this post I did the same thing as julzee and Wooo problem solved. I did not have my desktop icons for over 4 months and it was driving me crazy. Thanks Again
