Solved Details pane problem help!!
pramodm
DEAR FRIENDS,
PLS HAVE A LOOK AT THE PICTURE THAT I HAVE ATTACHED. AS U CAN SEE THE DETAILS PANE HAS SOMEHOW REACHED ON THE TOP OF THE WINDOWS RATHER THAN AT THE BOTTOM. I DONT KNOW HOW IT HAPPENED. COULD U PLS HELP ME OUT WITH THIS PROBLEM?? I NEED TO GET MY DETAILS PANE BACK TO THE GROUND FLOOR.
THANK YOU,
PRAMODM
fadedrs
Lost in my own World
Power User
Not sure how you did that but i can not replicate it at all.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
fadedrs
Power User
found this maybe if you did it in reverse or changed the word TOP to BOTTOM it will work
NOTE: If you are getting error "Can't create file...", that means you have edited and saved the same file in past and there is a backup file which need to be deleted before saving this file again. Go to the folder containing this file and you'll see a similar file having "_original" in its name. Delete it and try to save the file in resource hacker.
In Longhorn the "Details Pane" was shown at Top but in Windows Vista its shown at bottom. Many ppl still like the good old top details pane like shown in my following AeroVG theme:
Here is a detailed tutorial for changing the "Details Pane" location from Bottom to Top in Windows Vista:
1. We'll have to edit "%windir%\System32\Shell32.dll" file. So first take ownership of this file using my following tutorial:
Add Take Ownership Option in File / Folder Context Menu in Windows Vista
2. Now open the file in Resource Hacker.
3. Goto "View -> Find Text" (or press Ctrl + F). It'll open Find box.
4. Now type following String in textbox:
layoutpos="bottom"
5. Click on "Find Next" button and it'll show the line containing this text.
6. You have to just replace "bottom" word with "top".
7. When you have done, click on "Compile Script" button.
8. Now press "F3" key and it'll show the next line containing the same text. Again do the same mentioned in 6th step.
9. Remember! You have to replace "bottom" word with "top" only in following locations:
3, 4, 5, 6, 19, 20, 21
10. If you also want to show the Details Pane at Top in Browse/Save/Open dialog boxes, then replace "bottom" word with "top" in 27 and 28 keys too.
11. That's it. You have done. Now save the file and restart your system to take affect.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
pramodm
layoutpos="bottom"
THANKS ALOT FADEDRS... THAT REALLY WRKD.. MY DETAILS PANE IS BACK UP AND RUNNING!!! :geek:
fadedrs
Power User
glad to help
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
