Ink
I recently installed a user made patch that enables Diablo 2 to be played in higher resolutions. The patch can be found at http://www.widescreengamingforum.com/downloads/D2MultiRes-v102.zip
I install the patch and do exactly as the readme says and receive the following error: Unable To Load D2MultiRes.dll. Exiting Diablo II
Anyone have any experience using this patch? If so, how did you get it to work?
Thanks-
Ink
Thanks-
Ink
