Did not load driver AFD.SYS- PC not booting up properly
Pokerking
Hello
When I boot up my PC it freezes after the Microsoft loading screen
What I have to do then is boot up in safe mode and then restart my pc.
I have reinstalled both my graphic's cards drivers and my Realtek NIC's drivers.
I have done a boot log and the main problem is :
Does anybody know about this system file and what can I do to fix it? Is it a driver?
Urgently need help
Please post back asap
Thanks
Poker
H2SO4
A bit of a numpty
AFD = Ancillary Function Driver
It's part of Winsock. It provides access to the rest of the network stack for apps and many components of the OS. Without it, browsers and mail clients wont work, just as an example.
Does the PC boot without errors into safe mode?
Does it boot into "safe mode + net"?
Do you have a Vista DVD or is this an OEM preinstall?
Pokerking
Thanks for your reply.
Yes the PC boots without errors into safe mode.
Yes the PC boots into "safe mode + networking".
Yes I have a Vista DVD..
So what now?:)
Flavius
Expelled
Pokerking
So what now?:)
Interesting.May any non -system aplication service cause this? Disable all non-system services (look here how to do that for test:How to perform a clean boot procedure to determine whether background programs are interfering with a game or a program that you currently use ) and run system in normal mode and we'll see results...
Im afraid this did not work.
Once I am in normal mode (boot up through safe mode and then restart in normal mode), I can restart back into normal mode. It is only when I shut down that I cannot boot directly back into normal mode.
Any ideas?
H2SO4
A bit of a numpty
Can you post more of that boot log here? I'm not entirely sure that failure to initialise afd.sys is by itself causing your cant-boot-from-cold symptom. That might be more of a side effect.
Also, are there any warnings or errors in the system event log during one of these problem boots? (Run eventvwr afterwards to check based on timestamps.)
Pokerking
Here are more from my boot log:
Multiple instances of:
Did not load driver @nettun.inf,%isatap.displayname%;Microsoft ISATAP Adapter
Did not load driver @nettun.inf,%tunmp.displayname%;Microsoft Tun Miniport Adapter
Did not load driver @hal.inf,%acpiapic.devicedesc%;ACPI x86-based PC
Did not load driver @netrasa.inf,%mp-l2tp-dispname%;WAN Miniport (L2TP)
Did not load driver @netrasa.inf,%mp-bh-dispname%;WAN Miniport (Network Monitor)
Did not load driver @netrasa.inf,%mp-ip-dispname%;WAN Miniport (IP)
Did not load driver @netrasa.inf,%mp-ipv6-dispname%;WAN Miniport (IPv6)
Did not load driver @netrasa.inf,%mp-pppoe-dispname%;WAN Miniport (PPPOE)
Did not load driver @netrasa.inf,%mp-pptp-dispname%;WAN Miniport (PPTP)
Did not load driver @netsstpa.inf,%mp-sstp-dispname%;WAN Miniport (SSTP)
Multiple instances of :
Did not load driver ASUS EAH4870 series
Did not load driver ATITool Driver
Did not load driver @oem32.inf,%rtl8168c.devicedesc%;Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)
Did not load driver @cpu.inf,%intelppm.devicedesc%;Intel Processor
Once into Event Viewer, the timestamps of the warnings coincide with my unsuccessful
attempts and direct booting.
This message is repeated multiple times.
Level : Warning
Source: Winlogon
Event ID: 6000
Task Category:None
When I went to event properties this is what it said:
- System
- Provider
[ Name] Microsoft-Windows-Winlogon
[ Guid] {DBE9B383-7CF3-4331-91CC-A3CB16A3B538}
[ EventSourceName] Wlclntfy
- EventID 6000
[ Qualifiers] 32768
Version 0
Level 3
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2009-03-14T06:36:32.000Z
EventRecordID 15653
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel Application
Computer PokerKing
Security
- EventData
GPClient
D9060000
Binary data:
In Words
0000: 000006D9
In Bytes
0000: D9 06 00 00 Ù...
H2SO4
A bit of a numpty
Last things first. The 6D9 data in the Winlogon event is almost certainly a Win32 status code. 6D9 hex is 1753 decimal, and hence:
V:\>net helpmsg 1753
There are no more endpoints available from the endpoint mapper.
The endpoint mapper failure would be a side-effect of other stuff on your machine not working by that point, so I think you should ignore the Winlogon event for now on the basis that it's expected given half the OS has failed to initialise :)
I also suspect AFD is another victim. There are more fundamental drivers in that list which appear to be having issues... and yet the list does seem rather network-y, at least the portions which you've pasted here.
Since the problem only occurs during a cold boot, I'd suggest you first flash your BIOS to the latest version. If that still does nothing for you, try pulling out the NIC temporarily and testing cold boot into normal mode without it. If the NIC is embedded, try disabling it completely in the BIOS (most BIOSes offer that functionality).
My gut feeling is that your issue is more BIOS/hardware than software. I could easily be wrong though.
Pokerking
how would I go about flashing my bios?
My motherboard is a Gigabyte G31M-S2L
Are there any dangers with relation to my hardware + software with flashing my bios?
Thanks for your help so far:D
H2SO4
A bit of a numpty
If you go to the Gigabyte website, there will be info on how to update the BIOS.
Are there dangers? Yeah. Flashing the BIOS is always a slightly nervous time because if something goes wrong half-way through you generally end up with an unbootable machine which cannot be fixed without some real low-level hardware trickery. That very rarely happens, as long as you follow the mobo manufacturer's advice.
Have backups of all your data first of course. That's just common sense.
DmD
Please can you tell me how you fixed your problem? I have the same issue and I'm stuck. By any chance do you have as CPU a Pentim 5 xx1 Ceddar Mill on 65nm ?
Pokerking
No I have Intel Core 2 Duo @3.00 GHz... E8400..
Too be honest I took it to a guy who repairs pc's.
The problem was out of my hands.. Seemed to just be a driver + reg issue.
Pokerking
bjn5053
My Vista system was hanging partway into the boot process. I'd been trying to find a solution for months. My boot log showed that it was hanging up on loading AFD.sys. I found a Windows Hotfix that solved my problem, which might solve your issue. Take a look at KB961775 here: New AFD connections fail when software that uses TDI drivers is installed on a Windows Server 2008 or Windows Vista SP1 system that is running on a computer that has multiple processors
Apparently there is an issue between AFD connections and anti-virus software. You have to request the hotfix from Microsoft (use this form: http://support.microsoft.com/hotfix/...775&kbln=en-us ), but you'll get a link from MS almost immediately.
I suggest that you uninstall your anti-spyware and anti-virus programs, install the hotfix and then re-install all of your anti-malware software. This worked for me.
mrodriguez
I also have exactly the same problem as the thread starter. I have tried updating the BIOS and the link to Vista. Sadly the hotfix does not work either if you are already running SP2. So if anyone out there knows how the origional thread starters problem can be fixed with a registry driver fix please continue this thread.
LOST AND VERY LOST
    Vaio
    duo amd
    Giga
    kingstone
    raedon
    generic
    all in one system
Yard Dog
Hello, you probably ought to start your own thread and have solutions posted for your computer issues. As this Thread is pretty old. Okay ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
mrodriguez
Thanks, but after a full night of going rerunning the system with bits off and on I just backed up and reloaded.
The system is running as per factory resets, and I am just going to turn off updates except for security and sit pretty.
Thanks anyway.
Regards
    Vaio
    duo amd
    Giga
    kingstone
    raedon
    generic
    all in one system
