Different Warcraft 3 Frozen Throne Problem in Windows 7
jalf
Okay, the problem is, after installing my Warcraft 3 Frozen Throne on my Windows 7 beta, 7000build. I can run War3.exe after the installation. When I restarted my computer, the problem starts here.
Every time I open my War3, It minimizes on my task bar. When I click it again, it maximizes for around 1 second then minimizes again. I know its running fine because I can hear the sounds of the program and I can see the menu for 1 second.
I'm wondering if this is fixable. I search the internet for similar problem but it looks like I'm the only one having this kind of problem.
I tried Updating my Video Card driver, I think I have the latest.
Thanks in advance whoever can fix this problem.
Tried system restore, no result.
Reinstalling my War3, it works. But, whenever I restart my computer, the problem appear again. I need to shutdown my computer.
Here is my Computer specification.
System Information
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7000) (7000.winmain_win7beta.081212-1400)
Processor: Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz (4 CPUs), ~2.3GHz
DirectX Version: DirectX 11
Physical RAM: 3581MB
Virtual Memory: 2047MB
Video Information
Video Card: NVIDIA NVIDIA GeForce 9600 GT (Prerelease - WDDM 1.1)
Video Memory: 2035 MB
Chip Type: GeForce 9600 GT
Driver Filename: nvd3dum.dll,nvwgf2um.dll
Driver Version: 7.15.0011.7923 | 11/20/2008 21:25:00
Disp Settings: Generic PnP Monitor | 1024 x 768 (32 bit) (75Hz)
Audio Information
Audio Device: Speakers (High Definition Audio Device)
Driver Name: HdAudio.sys
Driver Version: 6.01.7000.0000 | 12/13/2008 10:47:51
Default Sound Playback: true
Default Voice Playback: true
jalf
Done. I fixed it.
The problem is, with the windows 7 desktop Composition.
Here's the solution.
Go to the warcraft installation folder.
Select War3.exe then, right click it, properties.
Compatibility -> check disable desktop composition.
And no more, minimizing problem.
jalf <guest@xxxxxx-email.com> wrote in
news:9f9e4cbc8bb584a47e5db8873828ee10@xxxxxx-gateway.com:
> Compatibility -> check -disable desktop composition.-
Good find, did you send feedback to Microsoft?
Joe
jalf
No. And I think, Microsoft intentionally added that option because, it can't be fixed on their side. So, I think, it's up to the game producer to add some compatibility in their program.
It's just a thought anyway.
news:b2a216454dbce3db8d0ef9b5a4c5f815@xxxxxx-gateway.com:
Vista has the same "feature", Desktop Composition, but WC3:FT works just
fine on Vista, so this is probably a bug introduced in Windows 7, could be
based on your hardware or something else, but either way when you observe
something click the send feedback link.
Just my thought anyway.
Joe
A
not necessarily. I run TFT in Vista and i have the same problem. The
solutuion is the same turn off desktop composition.
> Joe
*bump*
guys please help me i got the same problem...
it doesnt work with "disable desktop composition"
Is there anyone who solute the prob in another way?
karam
i need some help plz i have everything exactly like u all the computer information and stuff like windows ultimate and 32 bit and everything but when i click on frozen throne it stops responding and it freezes. ive tried running as adminstator and compatibilty windows xp(2) and windows xp(3) but no use it just stops responding when i try to open it. plz help me
#9
I'm having a problem except Im using windows 7(Signed up on the wrong forum) I will be playing a game on battle.net(warcraft 3 TFT) I will for no reason lose my connection to battle.net,And when I try to go back on it will say "This cd key is currently in use by sheldon on warcraft 3 reign of chaos" I am sheldon and I'm playing battle.net through the frozen throne,I've run it in compatibility mode for vista sp2(isnt a windows 7) and disabled desktop composition,Should I try running as an administrator?I'm getting discouraged.Please help me Obi Wan Kenobi.
