Disc boot issue x64
Munksgaard
Hi everyone.
I have a boot issue since I got a Samsung SyncMaster 2233RZ, I have a black screen the first 30 second on startup, that is until I get to the login screen.
I tried hitting the F11-F12 keys but I still just get a regular startup instead of boot from disc.
How do I get to boot from the vista disc and what is wrong with my monitor, it can't be right it has to stand around and blink for 30 seconds..? :sarc:
    Intel Core 2 Duo E6750 @ 2666 MHz
    Asus P5N32-E SLI PLUS
    4096 MB (2 x 2048 DDR2-SDRAM)
    2x 8800GTS
    Samsung SyncMaster - 22 inches
    WDC (500 GB)
    High
    Logitech G9
    Logitech G15
Munksgaard
bump
trying to format my computer because C: was suddently on 1GB free hdd space with a total of 50GB, even though I only have windows, drivers and a few minor programs installed here.
All of a sudden I have 10GB of free hdd space and my computer runs horrible now, crash in games and generally loads slow while almost crashing.
I heard of a virus that downloads kiddy porn to your computer in places nearly impossible to find and im not at all any expert with my computer so I really hope there is someone out there who can help me fix this.
    2x 8800GTS
    WDC (500 GB)
    High
    Logitech G9
    Logitech G15
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Munksgaard
Thansk for replying. But please read my post one more time. I can't boot from the CD for some reason...
Hello Munksgaard,
If you have not already formated your computer, then you can change the time to zero in OPTION ONE of the tutorial below by unchecking the box for Time to Display the List of Operating Systems at Boot.
http://www.vistax64.com/tutorials/70563-boot-up.html
However, from your second post, it sounds like you need to do a clean reinstall of Vista. :(
http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html
    2x 8800GTS
    WDC (500 GB)
    High
    Logitech G9
    Logitech G15
Brink
Staff member
mvp
Try tapping another key like the spacebar instead when you see the "Press a key to boot from CD/DVD" at boot. You will only see it for 8 seconds to press a key before it continues with a normal startup. If you do not see this, then check you BIOS settings to make sure that you have the CD/DVD drive listed first in the boot priority list with the Vista hard drive second.
You might see if doing a system restore at boot using a restore point dated before this problem started to see if it may be able to fix it before doing a clean reinstall of Vista though.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Munksgaard
Okay Brink. Thank you for all the help I will try and if I can't get it to work I will destroy my hdd and buy a new one that should do the trick :D
    2x 8800GTS
    WDC (500 GB)
    High
    Logitech G9
    Logitech G15
Brink
Staff member
mvp
You're welcome. Please let us know how it went. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
