I have got a problem here with my pc. I have vista installed in C drive and there is another partition(G Drive) in which i store all my data and there is another partition(H Drive) of 20 GB and its free(i dont use it for anything). So i tried installing xp on this H drive but after copying all the files the system restarted and it gave a disk read error, press ctrl+alt+del to restart. and when i restarted the system, the same error comes again. So for the time being, i ran start up repair and now i m able to boot from vista. Is it possible to install XP on that H drive? If yes, please tell me how.
Thanks and Regards,
Dinesh.
Thanks and Regards,
Dinesh.
- Compaq
- intel core 2 duo T 5550 @ 1.83 MHz
- intel 965 chipset family
- 2 GB DDR 2 SD RAM @ 667 MHz
- Graphics Card(s)
- On board upto 358 MB RAM
- Onboard
- 15"
- 160 GB WDC
