Display Driver Stopped Responding and Has Recovered - nvlddmkm nVidia Driver
bataylor1314
Here are my system specs
Athlon 64 X2 3800
Asus A8N32SLI Deluxe
2x Geforce 7800 GT
2 GB (4x512) Crucial Ballistics 2-2-2-6
Vista Ultimate x64
Nvidia Forceware 100.65
I experience a driver crash and recovery from time to time, especially when playing newer 3D games (primarily Lord of the Rings Online). Anyone else having any similar problems?
MrBytes
Athlon 64 X2 3800
2x Geforce 7800 GT
Vista Ultimate x64
Hi.
This driver it´s in beta version, remembered, only you need put in mode sli, only one GPU, and the porblem finish. I have 2x 6800, and y resolver with this way.
regards.
bataylor1314
The driver I am using is the 100.65 which is not a beta driver. It is WHQL certified. The 101.41 is the beta driver at the moment. 100.65 does not support SLI on my chip, so I do not believe that is an issue. The 101.41 driver does support SLI, but when install that games have very poor performance.
Gir
i have been seeing this error alot on the internet:mad: mostly in the 8series ... kinda sucks cuz i just got the error yesterday while playing wow... my puter has been working great up to that point and now i am really mad cuz i cant ever play oblivion :cry: all i can do is serf the web and i wanted to know if anyone has found the fix to it? i would love them forever if they let me know :D
zigzag3143
Banned
Gir
have you tried the fix in the post just before yours?
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Gir
well i would of tried the way to fix it in the post before me but if you click on the link it dose says "Unfortunately, this fix is temporary…the problem will likely come back and you will have to do it again." i don't fell like i should have to do something ever time the error occurs ... i just don't understand why it just started happening..... i have had the grafix card for while and there is no reason why it would do this but i guess if this is the only fix i can find i guess it will have to do tell if pin point the real problem.... once again if anyone know how to really fix it or know why it dose this please let me know
zigzag3143
Banned
My apologies you are absolutly right if it is a fis you dont have to re-apply it every time you want to game. let me do some research to see if anything had been resolved
ken
Edit possible fix
During the installation of the current drivers, an OLD file
nvlddmkm.sys is copied or left in windows/system32/drivers and not the current onein the install. As a result the new drivers are attempting to access an older file instead of the latest.
Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
nvlddmkm.sys.old. Go to the nvidia directory and find the file nvlddmkm.sy_ for your current drivers and copy it to windows/system32.
Using the cmd window (DOS box) type
EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete, copy
the new nvlddmkm.sys to windows/system32/drivers and restart the computer.
Your computer should now work properly.
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Gir
that would be so cool... but i tryed the thing that guy said... yah didnt work:cry: just my luck :( atm we are testing out if it is the grafix card that is making the problum happen witch would really piddle me off cuz the grafix card is not even a year old. i will keep you updated:D
zigzag3143
Banned
I will keep looking
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Gir
tryed the possible fix you posted.. well my boyfriend did.. he did it all and it gave the blue screen of DEATH! the most worse screen you could ever see... so i am guessing it must be the grafix card it self. but i dont see why it would just out of the blue happen but if you do find anything let me know
zigzag3143
Banned
If you can go to c:\winodws\minidump. there you should find a dump file (*.dmp). can you zip the dump file and upload it to us so we can debug it?
Let us know if you need help with any of this
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
CarolinaFaithful
    Intel Core Duo E6600 (Conroe)
    Gigabyte P35-DS3R (Rev. 1.0)
    Corsair 2x2048-6400C4DHX
    NVIDIA GeForce FX 5500
    Creative Sound Blaster Audigy SE
    Samsung SyncMaster 720n
    Seagate Barracuda 7200.10 500GB ST3500630A
    Ultra LS 500Watt
    PowerUp 5511 Silver ATX Mid-Tower TC3J-4032 P
    Cooler Master X Dream 4
    Logitech RX300
    Logitech Internet 350
    21.46Mb/s
Peppurr101
Power User
Gir- Have you seen nvlddmkm stopped responding and has recovered. The author gives twelve possible solutions.
For what it's worth, I had the same problem a while back (can't seem to find the post :huh:though). I had downloaded and installed updates for 'help' files for Microsoft Office.
I know it sounds unrelated, but I did it twice in six months with the exact same error message and also had trouble rebooting.
These updates were old (09/08) but it might be worth looking into what has been updated just before this started?
Might be a long shot, but it might help..
    Dell XPS 420
    Intel (R) Core(TM) Quad 6600 @2.4GHz
    4GB dual channel DDR2 667MHZ [4x 1024]
    NVIDIA GeForce 8800 GTX
    Creative SB X-Fi
    Generic Dell PnP Monitor
    2 500GB Hard drives in a RAID 1 Mirror configuration.
    Standard optical mouse
    Standard USB QWERTY keyboard
    Actual 2.2 Mbps
    Connected to DSL internet via ethernet via Netgear DGN2000 modem router.
    Also connected via ethernet to HP 8180 All-in-One Photosmart printer.
    19-in1 card reader and 1 DVD and 1 DVD RW drives
is there still a problem with it? (are you also receiving a pop up after the crash sayin "Display driver nvlddmkm stopped responding and has successfully recovered")
I know what the problem is,, and how i got it solved with mine.
    Acer Aspire M3641
    Intel(R) Core(TM)2 Quad Q8200 @ 2.33GHz(4CPUs), ~2.3GHz
    Acer MCP73PV
    4094MB RAM
    NVIDIA GeForce G100
    Realtex High Definition Audio
    Samsung SyncMaster 923nw
    1440 x 990 (32bit)(60Hz)
    Station #1 - WDC WD6400AAKS-22A7B (596 GB)
    Station #6 - HDT722525DLAT80 (232 GB)
    5 MB/s
jonmal123
I had this problem out of nowhere. Tried numerous fixes and no joy. Today I knocked back the resolution one click (from 1280x1042 to 1280x960) and it has stopped happening. (so far)
Arxachilleus
Suddenly i got this BSOD tonight....i was playing Aion screen froze for about 2 min and i pressed froze....I have tried all methods mentioned in the internet but ...no solution....WHen i log i cant do anything ....i can log on vista only with the default drivers(after wipe with Driver sweaper)
My system
Windows Vista Ultimate 64
Intel Core 2 CPU 6420 2.13Mhz
4GB RAM
NVIDIA 8880 GTS 512ram
also i noticed that when i boot onP there is no such a problem i can change screen resolution(on vista i can only to 1280*1024 with the defualt drivers-with laters 191.03 i can t even login screen froze)
Arxachilleus
My system
4GB RAM
  • Minidump.zip
ManWhoFalls
I had this start happening to me a few months ago. For a whole year I had no issues; I could play heavy games like Mass Effect, Fallout 3, and FEAR 2 on my pc with nary a blip on the screen. Then it started crashing in-game with the "nvlddmkm Has Stopped Responding and Recovered." needless to say, I want to tear my hair out, because now my computer is just a very expensive word processor.
I've been trolling through all kinds of forums, and this problem seems to have it's roots all the way back in 2007, and no one fixed it then. PLEASE someone give us a concrete solution to this.
My system:
Windows Vista Home Premium Pack 32 bit
Direct X 10.1
Nvidia Geforce 8800GT (Driver v. 195.62)
Intel Core 2 Quad CPU Q6600 @ 2.4 GHz
Memory: 3.00 GB
