Does most applications need to extract file to temporary folder before it be able to install?
- HP
- 2 G
- HP
- 2 G
- Graphics Card(s)
- AMD
- REALTEK
Hello Stuckfree,
Yes, generally most of the software are available as extractable files. An easy way to identify this is that the software package will be available as an install .exe file. However, some software packages are also available as a bundle of various required files which contains the setup file.
Hi roy69,Simple yes, as has been said by, Allan D
Hello Stuckfree,
The self-extractor will extract all the files in the bundle.
