does this sound like a graphics card issue?
4
okay so my power went out and when it came back on it fried the power supply, i got that fixed but my samsung tv says the resolution is not right even though nothing has changed. This leads me to believe my graphics card got screwed up by the power surge and now is screwing up or something, first can you tell me if that is plausible? second I want to know if I can unplug my graphics card and turn on my computer and is their any chance it would then work? I don't exactly know what a graphics card does for all I know the thing could be not broken if you don't think it is the graphics card could you tell me what you think it might be? I will of course replace my graphics card but just want to know if that is an easy way of finding the problem. the bios screen does not come up when I turn it on and neither does safety mode and it will work on a computer monitor but I need it for my tv.
Patonb
2,245
I think it is your graphic card. Power surges are very nasty. Graphic cards are your video card. The part that shows you what you see on the screen.
Cann you tell me your computer model so i can better help the issue.
Its odd your bios screen isnt showing, as thats not even a windows operation, is weird.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
townsbg
~~тσωηsвg~~
2,248
Location
US of A
Have you tried using a regular monitor? Is this a laptop or desktop?
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
4
it's a desktop and the guy at the computer place showed me it was working with a normal computer monitor so yeah they work. and I don't really know the model I sorta just had the computer place build me the best computer they could for my money its a bunch of different parts and I don 't have a list of them.
richc46
Staff member
20,105
Location
Fairfield County, CT
Yard Dog
2,169
Location
Central Florida in a small town
Hi, just passing through, try free of Speccy, gives a list of hardware you have. Free also. : Speccy - Download
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yard Dog
2,169
Location
#8
Try hooking up another monitor to it
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
2,169
Location
#10
Okay, but, not the one hooked up to it now ? Hmmm, i am at a loss here as how to advise you.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
richc46
Staff member
20,105
Location
#11
Unless I missed something, it is apparently a bad monitor or the driver for the bad monitor. Has nothing to do with the graphics card. Dont you agree?
Did you try to reset the monitor resolution? It could be that the shutdown caused the resolution to change.
wither 3
2,227
#12
Let me understand something you said in your first post.
You said it doesn't work with your TV but it does work with a computer monitor. Is that true?
When you connect to a computer monitor, are you using the VGA port or DVI port?
What about when you connect to the TV?
If you're using different ports, one part of the video card could be damaged or possibly the connecting cable is damaged.
Patonb
2,245
#13
The one thing when you say it works on a monitor... Is the resolution proper? As things will run just fine on monitors, but as your tv isnt "standard" if the gpu is messed it'll show it.
You really need to get your setup listed.
Yard Dog
2,169
Location
#14
Yep, agreed , hook up a monitor, and get the specs from sites Rich and I have listed, to assist Patonb on helping you out.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
