Down/Up load throttle / Firewall
Ryuho
22
Location
California, USA
Is there a program that can throttle local internet connections (local as in your own computer) that works on, or more preferably, optimized for vista x64?
I already looked into netlimiter, I was wondering if there is anything else that I missed that you guys are using.
    Intel E8500 @ 3.16Ghz
    EVGA nForce 750i SLI FTW
    OCZ Reaper HPC 4GB (2 x 2GB) DDR2 1066 (PC2 8500)
    MSI N260GTX-T2D896 OC GeForce
    WD6400AAKS 640GB 7200 RPM 16MB Cache SATA
johngalt
Antidisestablishmentarian
3,909
Location
3rd Rock
Honestly I have never found anything *but* netlimiter for throttling....
Then again, though, I have never looked for it other than looking for clients / friends.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
Ryuho
22
Location
California, USA
Damn.. they even have x64 version.. maybe I should actually buy a piece of software rather than mooching on freewares and open source projects...
NetLimiter 2 Pro $29.95 hmmmm...
johngalt
3,909
Location
3rd Rock
There has to be something else out there- I'd search BetaNews (aka File Forum) for their stuff....I usually find really really good freeware and Open Source there.
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
Ryuho
22
Location
California, USA
Thanks, I'll look around BetaNews and sourceforge and other places.
It seems like a common thing people would want, I mean you can block and unblock connections on all firewall programs.. (it's what they do lol) I just want to do that... with a limit.
johngalt
3,909
Location
3rd Rock
Almost as a reverse QoS - I feel ya.
If I happen to run across anything I'll post back.
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
