Downloads problems
r0xy
4
Can someone please help.?
I cannot download for example drivers (never gets past 0% loaded) and other .exe downloads, youtube videos freeze after about 3 secs, and some websites do not open (although multi-clicking them sometimes helps). I am lost at what to do.
Please help.
System is Win Vista Home Premium
AMD Athlon64 64 X3 TK-57
Many Thanks
Roxy
    Dell Vostro 1000
richc46
Staff member
20,105
Location
Fairfield County, CT
Roxy
Although it may not be the problem this time, these are classic symptoms of a virus.
Try to update your anti virus and run a full scan.
If you can download malwarebytes and make a full scan
With your current problem do what you can and report back
r0xy
4
Roxy
Dear Sir
Thank you for advice. However, after scan with my McAfee, there was a virus that has been cleared, but problem remains. Can you or somebody offer further advice.
Much Appreciated
    Dell Vostro 1000
Yard Dog
2,169
Location
Central Florida in a small town
Hello and welcome to the Forums, as you have download issues and McAfee found one threat, please use this : ESET :: Get a FREE Online Virus Scan
When the scan completes, push List of found threats
Push export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
Push the Back button.
Push Finish
NOTE: In some instances if no malware is found there will be no log produced.
Post back with that log if able to use this please.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
richc46
Staff member
20,105
Location
Download malwarebytes, update it and make a full scan
If negative, using another computer save the download to a finger drive and then see if you can install from there.
r0xy
4
Unable to load Malwarebytes (freezes at 39% download).
    Dell Vostro 1000
r0xy
4
Push Finish
I have been unable to download ESET. Can you suggest anything ese? Many Thanks
    Dell Vostro 1000
Yard Dog
2,169
Location
#8
Nevermind, it said no downloads if using IE>. i just tried it with IE and it does indeed want you to install a part of it. Use another computer to make a dvd/cd or thumb drive as Rich has suggested , use the Malwarebytes first . Just so you know, i use Firefox , and i did download that program and even though i use MSE and a paid Malwarebytes , Eset still found 5 issues , which kinda surprised me.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
64
Location
Canada
#9
Hello Roxy,
This might be a root kit,One in general(Zero Access). If you could get your MAch. into Safe mode with Networking
and then go online to Anti-rootkit utility TDSSKiller (SAFE MODE)w/networking:> How to start Windows in Safe Mode or Safe Mode with Networking - ESET Knowledgebase
about mid page click on the download for the .zip & open folder
you may need 7-zip or some comparable to open zip files.
Once extracted you will have a folder open with a read me file and the Tdskiller.exe file/double click to run.
then you will be prompted to update click update.
let it go to update and open update, then run scan/
hopefully you can find and heal if it is a root kit.
Please respond if you try this option./
Sixwheeler
    HP/Compac Pasario SR
    Single 3.42Ghz rated 4.0
    Unknown
    3GB
    3450 series ATI Radeon 512MB
    Realtek HD Audio
    CRT 17' Compac
    150GB/OS
    40GB/Internal/storage
    Black 5 USB Ports/CD/DVD RW/R
    Double Fans/Single CPU Fan
    USB Optical Mouse Optimal/Stobe
    HP
