Drag and Drop not working
Last night as I was moving a file in Windows Explorer, I discovered Windows wouldn't let me drag and drop the file to a folder. I've had problems with drag and drop not working in Outlook 2007, but this is the first time in Windows Explorer. How can I fix this?
I am runnning Vista Home Premium SP1 32bit and I am the sole user.
tom982
٩(͡๏̯͡๏)۶
Try check your Esc key.... Do this physically by pressing it several times. then try Drag and Drop function. It works for me. :sarc:
Hello p2471c and welcome to the forums :party:
Thanks for sharing your solution! I'm sure others will appreciate your efforts. Although this thread was from 08-28-2008, so hopefully it's been solved :)
Tom
