DREAM SCENE PROBLEMS.. please urgent
Status
Not open for further replies.
Shahan_ogLy
trouble with dream scene
i have downloaded almost all important updates including dream scene
but i cannot use it, because when u press browse in desktop background there is no video to select... what is trouble?
didn't i activate it or something??? i cannot understand..
please people help me..
my system is windows Vista ultimate 64
and by the way.. when u i want to switch on or off features the list is empty
even after i installed stardock software it cannot
    Logitech MX Master 4
The sfc/ verifyonly command that you ran does not fix anything. It just sees if there is a problem and reports it in the CBS.log if it finds anything. You will need to run the sfc /scannow command to actually have it attempt to fix what it found wrong.
Have you run the sfc /scannow command yet?
may sound silly but in the desktop background menu there is a dropdown menu titled dreamescene which looking at the pics you suplied aren't looking in for the dreamscene dreamescene.JPG it is in this menu which you will find your vids if this isn't there look through your updates to see if it failed the install if so uninstall it ensuring to check the option for windows components
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
hey bro
what r u talking about??? i dont understand u... look at the first picture properly
but i find that
it can play the only one wallpaper and while trying to set other wallpaper it say that not installed dream scene (refer to picture)
i see that, it seems like it's not there at all if you have installed it try this
link for help on it: Windows Vista Help: About Windows DreamScene
you may want to try uninstalling it then relaunching the update which should reappear however others may know differently.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
Shahan_ogLy,
It appears that something is really corrupted causing this. Other than a clean reinstall and starting over, I do not know what else will let you possible install DreamScene so that it will work for you. :(
Perhaps Stardock Deskscapes has something to do with the problem? Only a thought.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
That is weird. Just out of interest what choices are available in the drop down menu when you click the down arrow in the attached thumbnail?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
choices appeared only after when I install stardock... before that it wasn't there... by the way, Web folder is empty also.... please refer to pictures
..and the Windows Dreamscenes one is empty?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Then it looks like a format and reinstall I'm afraid. The installation is fouled up.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Curious...does Windows Aero work? The reason I ask is that Dreamscene requires a video card that supports Aero.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Status
