Dreamscene Problem...Faster Graphics Card??
gtiboy
4
Hi all,
I currently have a problem with running dreamscene, it slows my computer down when running it, as soon as I open up other windows. Also moving windows around the desktop is noticebly slower, along with the fact dreamscene stutters.
I currently use a Nvidia Geforce 7300se which is intergrated graphics.
I was looking to upgrade to a cheap ATI HD3450 graphics card to solve this problem.
Does anyone here know if the HD3450 will speed up dreamscene to its optimal level along with using and opening up windows without slow downs?
    Packard Bell Imedia 1559
    Intel Pentium D820 2.8GHz, 800MHz FSB, 2MB Cache
    2GB DDR2 Corsair Value Select
    Nvidia Geforce 7300SE
    Asus Xonar Essence STX
    Sony SDME-E96D 19" LCD Monitor
    1280 x 1024
    160HD
    250Watt
2,456
Location
NY USA
gtiboy
Any chance we could get your system specs. you can fill them in in the lower left corner.
We need to know what kind of hardware you have
Ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
gtiboy
4
Updated my specs, Just wondering if my problem with dreamscene is GPU related, since Vista is heavy on system resources such as Aero.
    1280 x 1024
    160HD
    250Watt
yes it would help..... and thats about the best you could get without upgrading your psu..... i can't say how much it would help... but it would be better than your integrated
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
you should have one open pci-e slot.... a 3450 in that would make things better
    1680 X 1050
    6 Mbs Down 1 Mbs Up
gtiboy
4
Yeah I do have a pcie slot, so you reckon a HD3450 would do the job?
what would say for the specs of the HD3450 against the 7300SE, have the specs on the gpureview website below.
Video Card Comparison - GPUReview.com
    1280 x 1024
    160HD
    250Watt
it might...... if you have a little bit of a budget though.... the best thing to do would be to get a slightly better psu.... (like a 400 watt) and a HD3650 or a HD3870..... and then you would def would have no problems.....
    1680 X 1050
    6 Mbs Down 1 Mbs Up
