Smudge5705
Help needed
I currently have a HP P6061uk PC and already have a Dlink PCI card installed for Wifi. I have just purchased a Dynamode WL-GI-600-11N PCI card to replace it from www.scan.co.uk. The problem I am having is that when I plug the card into the slot Vista does not detect it and no new hardware found. I then try to run the set up disk that came with it that states Vista compatible and an error is returned. I have also tried to install direct from a folder and it just loops stating that I need to plug the card in first.
I have looked on the Dynamode site and the card is not even listed, no response from the many emails sent to support and calls just go to a busy rann.
Im running Vista Home Prem 64bit.
I have been able to install the card in an XP PC without any issues so I know its not a card fault.
Any help you can offer would be gratefully received.
- HP Pavilion p6061uk
- Intel® Core™2 Quad processor Q8200
- Asus IPIBL-LB HP name Benicia-GL8E
- 4 GB DDR2-SDRAM
- Graphics Card(s)
- ATI Radeon® HD 4650, with Avivo technology
- Onboard Audio CODEC: ALC888S 7.1 channel high-definition aud
- HP 2009v
- 1 TB C:Drive
- PSU
- HP
- Case
- HP
- Cooling
- HP
- HP
- HP
- 10meg
- Other Info
- Link to HP site
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684404&lc=en&dlc=en&cc=my&lang=en&product=3923158
