Solved Drivers for Rapoo Bluetooth Headphones
denret
I'm trying get Rapoo Bluetooth headphones to work on Vista 64. They Bluetooth link OK, but Vista
can't find drivers. I contacted the Mfg, they say Vista should supply.....confused.
I checked, and noticed that I am still running SP1. Will installing SP2 help me out with Bluetooth support
or am I going in the wrong direction here??
wither 3
Yes, install SP2. Let us know if it helps.
After installing, there will be lots of updates to install.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
denret
I upgraded to SP2. It did absolutely no good.
I did however finally get the drivers installed.
I used a different Bluetooth dongle.......the one that I had been using was a Version 3. I replaced it with
a Version 2.2, and the drivers loaded on first attempt.
I guess the Rapoo Headset only likes a Version 2 dongle???? I was not aware that bluetooth perhipheral devices
were version sensitive, but I'll be aware of that potential issue in the future.
wither 3
Have you installed all the updates after installing SP2?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
Reading the description of that app, I don't know if you want it or not. I don't have a need for it.
There should be roughly 150 updates after installing SP2.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
denret
Even though I've got it working with the Version 2 dongle, I'm going to keep plugging away.
It seems as though the drivers should load to any Version of dongle, but then I don't understanding the relationship between the Bluetooth radio, Vista, and the drivers?
