dual boot-vista ultimate 64/ home basic 32?
Posts
12
Can it be done? I've searched the dual boot threads and if I'm understanding them it can be, but before I buy another os I just wanted to check.
Bare Foot Kid
R.I.P. August 13th 2014
The Lowcountry
Posts
2,616
I am very new at this but I was just told today
that it can be done.
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Posts
12
My problem is a driver issue. Im pretty sure that the os will load but it will be on the 64 bit machine so does that mean that the driver for the wife's scrapbook thingy would be the vista 32 driver (os I boot up in) or the vista 64 driver (that doesn't exist and probably will never) that the machine is? If this would work it will really get me out of the doghouse so please help
Brink
Staff member
mvp
Oklahoma, USA
Posts
32,265
Hi boyce,
Yes, you will be able to dual boot with one partition or drive having 64 bit Vista and the other 32 bit Vista. It does not matter which one you install first. You just need to be sure that you have all the drivers for your devices for both the 32 bit and 64 bit versions of them.
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
