dual-monitor: apps starting in secondary screen instead of primary
anfrey
i've got a minor issue where some apps choose to launch on the secondary screen, rather than my primary. i believe it is because my secondary is actually to the left of the primary (it is a TV that is physically to the left of me). is there a way to tell apps which screen to launch in? i'd rather have all my apps launch on the primary display.
johngalt
Antidisestablishmentarianist
Vista goes screwy with this sometimes - but mostly, I have noticed, when I run WMC and it opens in the window that the app is in.
Try running WMC on your TV so that it forces the app to the other 'monitor' and then hit the start button on your KB, freeing your mouse from WMC, and then go to the other monitor and close the app(s). Then close WMC and see if the app opens back on the TV or in the monitor.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Kotuku
Power User
If you right click on desktop and select DISPLAY SETTINGS, you can drag the visible screens around to match your Left Right combination (I have 2 screens with primary as the #1 on the right). This should be set as the Main Monitor and Extend the desktop onto this monitor, both those options are greyed out on the #1 monitor. In the drop down box, bring up the #2 monitor or just click its icon. That should have only the "Extend the desktop to this monitor" ticked.
If an app opens on the wrong screen, drag it to the correct screen and close it down. Then when it opens again, it should open on the one you dragged it to
    Intel Core2 Extreme Quad Core
    XFX MB-N790-IUL9 NFORCE 790 U
    4 Gb (2x2) Gskill DD3 1600
    XFX 9800GX2 Black Ed. 1Gb DD3
    2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
