Solved Dual monitor setup
Is it worth setting up two monitors. I have an opportunity to get a brand new gateway 19" monitor for $100, still in the box. How hard is it to set up and what would the main benefits of dual monitor setup? Most of all would I really like it if I did a dual set up. Any body else have a dual set up, do you like it. Thanks.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Brink
Staff member
mvp
Hello Bassfisher,
If your graphics card as a secondary output on it, then your good to go with just connecting the monitor to the secondary connector on the card and installing the monitor's driver (if it has one). Pretty much that simple.
It really depends on your needs, but it makes having multiple windows opened a lot easier to see and organize by dragging some of them over to the second monitor.
I like it. :)
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
z3r010
Staff member
If you have the outputs for two monitors on your graphics card then get the second monitor, I would recommend using at least two screens to anybody that can.
As for setup, it's pretty much plug any play ;)
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Airbot
I have a dual setup with my 19'' gateway LCD and my 38'' Sanyo Hi Def TV. My ATI HD card has a individual HDMI input as well as my TV. Works good.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Thanks guys. Yes my card has dual input...DVI, VGA. So I'm good there. Pretty much PNP, it can't be that easy can it....lol. Now my only problem is that I''m out of outlets on my UPS...8 and there all full. Damn it, now I have to get another surge protector and do some moving of plugs on the UPS. Thanks again for the input. When I get it hooked up and set up I'll post back with my results. Maybe this time I'll take some pictures and post in the "show us your rig" forum.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Brink
Staff member
mvp
You're welcome Bassfisher. Enjoy your new dual monitor setup. :)
    Lumia 1520 phone
nvader
Be careful with dual monitors though. Once you use them, you can never go back to one, it will spoil you quick. At least with LCD screens it is better than the dual 19" CRT I had 5 years ago.
I've tried as many as four monitors with two pci-e nvidia cards (works as long as both cards use the same driver) but went back to two. Only time I actually needed three was on a time crunched web-site recovery from a hosting change.
Two has been mandatory now for anything I do graphically. Enjoy your new desktop space!
    Home Built
    AMD Phenom II 920
    GB MA790GP-DSH4
    OCZ Platinum 8GB PC21066
    Sappire Radeon HD4830 512
    HDAudio onboard
    Dell 22" Asus 22"
    1680X1050 1920X1080
    Seagate 500GB
    Seagate 1.5TB
    Sumsung 500GB
    WD 74.5 Raptor
    OCz 650watt
    Cooler Master CM690
    6X120mm
    Logitech LX8
    Saitek Eclipse II
    DSL 5mb
    Tweaked by vistax64.com
Uloga
It's really weird to go back from 2 screens to 1 as nVader says. You really get used to the 2 screens. I have a 21" main, and a 15" secondary, which I use for Winamp. Though some games messes up the thing. When you're gaming and you click the secondary screen, your game is messed up sometimes.
Just wanted to warn you to turn of the 2nd screen when playing some games
lukeroberts
yea im with Uloga on that one i always turn my second 17'' off when im playing games. but when i do audio editing etc its awesome to be able to quickly mutitask with programs.
    ME Model #lukeroberts
    AMD Phenom II x3 720 Black Edition
    Gigabyte / XFX
    6 GB/3 GB
    ATI Radeon 4870
    25.5" Viewsonic / 19" LG / 17" NEC
    1920x1200
    500 GB Seagate Barracuda x3
    Rocketfish(lol) 700w SLI
    Logitech G11
stormy13
One word for fixing that, Ultramon,
Realtime Soft UltraMon
In addition to all the other features/benefits of it, it also has hotkey functionality; comes in very handy with those games like you guys describe to lock the mouse to the primary monitor.
Not free, but what it offers makes it worth it in my opinion.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
OK, I have my 2nd monitor up and running now. My problem is how to I get some or all of my apps on to 2nd monitor. I have tried drag/drop but when I do, what ever I drop just disappears and I don't have that particular app on any computer. What do I do now?
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Dunkelseele
Possible solve
Hi!
I work also with two displays, mostly because of comfort and also because Photoshop takes quite a large space for all the secondary tool-windows. I like to have 'em open all the time. Also nice for After Effects as you can get easily three displays full of controls and setting-windows. Crazy! But a pleasure to surf and work with, I don't want to miss my two 16:9's... ;)
Your problem:
Just open up the "display"-options in your system control. You can see the black boxes who represent your monitors. Drag 'n drop them until they fit your physical position of the two devices. Make also sure that the checkbox saying something like "expand desktop to this device" is checked. The rest is self-explanatory. That should solve the issue, at least I hope so.
Best regards,
Noël
    Intel(R) Core(TM)2 Duo E8400 @2x3,00Ghz
    MSI P35 Neo
    2x 2Gb
    Nvidia Geforce 9800GT @512Mb
    Onboard Realtek
    2x Samsung SyncMaster 943NW
    1440x900 Pixels
    1x Samsung 40 Gib
    1x Samsung 80 Gib
    1x Samsung 500 Gib
Moving the black boxes to any position does not do any thing and the box is is checked. So now what do I do.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Dunkelseele
Hm. Alright, maybe your graphic drivers are outdated? The usual guess. I admit, I have no clue what's wrong. What exactly does happen when you put a window out of the normal desktop-space of your main monitor? and what does the new monitor show, the desktop background? Another hint: Nvidia has the "Nvidia control panel" from which you can also access a setup-wizard for multiple monitors, and tweak some options you normally can't access.
Best regards,
Noël
    MSI P35 Neo
    2x 2Gb
    Onboard Realtek
    1440x900 Pixels
    1x Samsung 40 Gib
    1x Samsung 80 Gib
    1x Samsung 500 Gib
Best regards,
Noël
I just updated graphics driver and it lowered my WIE score. Not sure on the next question, the new monitor shows a distorted wall paper of monitor 1. I have used the Nvidia control panel that is how I got to where I am now.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Best regards,
Noël
I played around in the Nvidia control panel and went item by item to find out it was my refresh rate. I change it from 60 hertz to 75 and bingo I have access to my second monitor. I should have checked that right from the get go...I guess I'll learn that some time.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Dunkelseele
I was just about to ask you if the refresh rates are calibrated. A bit too slow. ; )
Good that it works now.
Best regards,
Noël
    MSI P35 Neo
    2x 2Gb
    Onboard Realtek
    1440x900 Pixels
    1x Samsung 40 Gib
    1x Samsung 80 Gib
    1x Samsung 500 Gib
phil1ooo
UltraMon is just the best when using dual monitors as it saves so much time minimising and maximising from screen to screen.
I will say this much;Once you get used to using dual monitors you will not only never want to go back to using 1 but you will be lost when ever you do use 1 monitor as dual monitors just expands your capabilities 8 fold.
Have fun
