Dual monitors & Media Center
macool
I've been using Vista Media Center on a dual monitor setup which works fine except for one niggly little problem. When watching TV I have MC open on my second monitor while I work on the primary monitor but if I run MC full screen the cursor is locked in and I can't move it back to the main monitor.
I can drag the MC to almost full screen and everything is fine. I also have Power Cinema which doesn't have this problem.
Just wondering if anybody knows of a solution as I like Media Center and would prefer to use it.
Thanks.
swarfega
da Cleaner
Vista Pro
Thats typical behavior of fullscreen applications, games do it as well. Your "almost full screen" solution is the best.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
orkel
What I have found id that by pressing the windows button on the keyboard, allows me to move the mouse out of the MC monitor that I have it on.
This is the only solution I found that works, if you would like to use full screen
johngalt
Antidisestablishmentarianist
You beat me to it Orkel - this is exactly what I do as well.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt
Good program - I'll email the author to allow for settings to automatically load MCE on the primary monitor in a FTS mode that leaves the mouse usable on the second screen....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
ThÉoPatrizi
That is sooooo GOOD!
I used to leave a window opened on the main monitor, open WMC, maximize WMC and do alt tab to the windows i left opened on the main..........
to much work!
    Athlon x2 4400
    Asus M2N-E SLI
    2x Kingston 1GB ddr2 667mhz
    Geforce 8500GT
    2x Seagate 250gb = 1 500gb raid-0 stripe.
johngalt
Yeah, just hitting the start button on your KB does the same thing - you don't have to open the second window at all.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
geku
Hi Macool,
I'm still struggeling with the basic setup of running 2 monitors with windows media center (which you seem to have achieved).
I have a NVidia 8400GS and managed to have both monitors recognized by windows and configured properly. One is small TFT, that I would like to use as the console to runn the Media Center UI and the other one is TV, that I want to use for Video Output.
My question is: How do I configure Windows MC so when any kind of Video or TV is started, the output goes directly to the TV.
Any help is highly appreciated.
Thanks, Georg
Bellerophon
Vista Pro
    AMD Athlon 64 X2 5000+ Black Edition (3.2GHz)
    Asus Crosshair
    4GB Crosshair Dominator
    Sli 2 x LeadTek GeForce 7800GTX OC
    HP w2007v, Elo 17" Touchscreen, Sanyo 20", Philips 17"
    Samsung Spinpoint F1 500GB SATA II
    OCZ 850W GamexStream
    Thermaltake Tsunami Dream
    Scythe Ninja Copper Cooler 5th Anniversary Limited Edition
    Logitech Cordless Click! Plus
    Logitech Cordless, MCE Keyboard
    hamster powered
ThÉoPatrizi
Hey guys, I am having problem with the maxifier.
When it is installed, the MC does not works fine in the 2º monitor (TV).
With out the programa media center opens just fine on the last moniter it was used!
But, when I install the program.....
it opens in the 2º monitor, than it blinks and goes do the 1º monitor!!!
Any help?
Thanks.
    Athlon x2 4400
    Asus M2N-E SLI
    Geforce 8500GT
BostonTechGuy
I know this is an old thread, but just wanted to say, "Thanks Orkel!" I can't believe I never thought to try that! I've been putting off buying a third monitor for quite some time because of this one little annoyance. I've even sent a feature request to MS due to the fact that this existed since XP MCE, and still exists in Vista and Win7.
