dvd burns straight to hard drive not asking for blank dvd
Belinda
1
I am a novice with Vista. Have just bought a new lap top and tried to burn a DVD but instead of shrinking it then asking for a blank dvd to burn to it just saves to the hard drive.
I have dvd shrink which works fine but it doesnt seem to connect with the burner. I have downloaded a trial version of Nero 9 in case this helped but still burns to hard drive!!
Can anyone help?
PS- I noticed Vista will not accept the old Nero or Roxio!!
6
at the top of the nero screen there should be a drop down menu, i'm guessing image recorder is selected. Change that to your DVD writer and let me know if it works. If your writer isn't in the drop down then nero doesn't know how to use that drive.
19
Location
USA
Yeah I am Nero freak user and burner too, even to the point of burning DVD - DL's but when I installed nero I got the incompatable message but still installed it and it still failed to work. I LOVE NERO and would hate to have to try and learn some other software.
Please let me know how Nero 9 beta works for ya, ok?
On a side note it that doesn't work what do the experts here recomend using to burn DVDs. The MS application only burns Movies and pictures...and it doesn't as far as I can tell even let me select folders, just video files and picture files. That to me seemed rather short sighted by MS not to think people would want to burn data files or folders containing various files....:rolleyes:
    Core 2 Duo 2.66 E7200 3mb 1066FBS
    BioStar P43D2-A7 P35 PCI-E 1Gb Lan
    4GB PC 6400-800mhz
    NVidia 9500GT 1Gig Vid Ram
    Sound Blaster X-Fi Extreme
    Samsumg SyncMaster Magic CX2253BW 21 inch
    1600 x 900
    Maxtor SATA 2 250Gig
    Intel-775 Hyper-TX 3 Heat pipes
    MS intella Mouse USB
    MS internet keyboard pro USB
    Fast Broadband
bmx15
6
AFAIK. Vista allows you to use the explorer's built-in CD burning feature to burn data DVD-R's (XP could only do data CD-R's).
    Alienware
    Turion 64X2
    RadeonHD
    1536GB (internal)
    128GB (expresscard)
    1mbps
MilesAhead
Eclectician
2,442
Once I made the recovery set I got rid of the OEM burner stuff. I use Imgburn. I bought Nero 6 because back then there wasn't much in the way of freeware for doing conversions(and I didn't know that much about it so I wanted software to take care of the job) but now there's lots of very good quality freeware to convert most anything to DVD. Once you have the DVD image or VIDEO_TS folder authored, just use Imgburn to burn it. btw CDBurnerXP works fine in 32 bit Vista... also freeware. Even converts .flac files. Just drop them on an Audio CD template and it converts 'em.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
