dvd maker & movie maker 'dep' error
1
i upgraded from windows xp to vista recently and dvd burner didnt work, finally got that working now when i open dvd maker to burn a video it tells me it isnt working and will close...then showing me that its a Data Execution Protection problem. i cannot turn the dep off for these programs and am lost!!! movie maker tells me the same thing. anyone???
this is what i get!!!
Problem signature
Problem Event Name: BEX
Application Name: DVDMaker.exe
Application Version: 6.0.6001.18000
Application Timestamp: 479193d1
Fault Module Name: xvidcore.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 40e6f3e8
Exception Offset: 0a641080
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Files that help describe the problem
Version.txt
AppCompat.txt
memory.hdmp
minidump.mdmp
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Shanley,
You might see if doing a clean install instead with your upgrade Vista from XP may work better for you instead. Be sure to have all of your device drivers for Vista handy before to make it easier to install them afterwards. Sometimes doing a upgrade from XP to Vista will result in compatibility issues with remnants of the XP install still in the Vista installation.
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
