DVD RW Drive: Application Not Found
Kuham
Hi everyone,
Pls I need your valuable help.
My DVD RW drive as been working normally since I had my Dell Inspiron 530, but recently for 2 weeks now anytime I insert a cd or dvd it gives me this message: Applicantion not found. Pls what can I do. Its affecting my projects.
Thanks in anticipation
Kuham
richc46
Welcome
Several thing to try
Go to search by the start button.
Type device manager
Inside device manager look for any small yellow warning markers. If none found go to the driver for the drive and make sure that it is up to date
If that does not work, try a system restore from about 3 days before the problem began.
If that does not work, here are various suggestions from Microsoft
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/cddvd-drive-not-detected-by-windows/f0eb31fd-b5c9-43d8-89ff-b658685a8383
kesume
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
richc46
LOL Dont worry about that Keith, I have been doing this a long time and your answers are looking like mine already. Just exercise those fingers and I will have to type faster. You have beat me by seconds, several times already.
kesume
I'm not serious of course, quick typing nah! I respect your experience & organisational ability.
Good to be even close in recommendation time.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
kesume
After you have concluded the above recommendations by Richard, you might like to go to this link, where there are a number of instructional videos on such a problem as you have. Very informative and easy to follow.
http://www.youtube.com/watch?v=iBr8jLOXqTE
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
Kuham
Hi Guys,
Thank you very much, I'll go right away as you'v replied and get back to you soon.
I appreciate your quick responses.
Thanks
Cheers
Kuham
richc46
Take your time
If it works let us know, If not maybe we can suggest other ideas.
ilikefree
And if that fails,set a restore point and try this.
Press Windows key and R
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
