DVD stops working when Vista starts
knaymie
I haven't seen this problem discussed in other threads. I am able to access the DVD drive during the start up routine until Vista gets running. Any ides about what the problem might be? Thanks for your help.
richc46
knaymie
Richc46, I can't thank you enough for your help. Using the tutorial that you linked me to, I was able to find out that the conflict was with my external hard drive.
richc46
You have thanked me enough. We are all volunteers and work for the great feeling of satisfaction that we receive when we help. That thank you is worth its weight in gold.
knaymie
I am no longer able to operate the DVD with clean start up. It did work when I first tried it. The DVD doesn't work in safe mode either. The device manager says that the DVD is working properly and the drivers are up to date. Any ideas?
wither 3
I would uninstall the drive or disconnect it and reboot. If disconnect was used, reconnect once Windows is running.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
