dw20.exe MSVCR80.dll was not found
47
Not sure if this is right thread but anyway,
I have recently experienced a problem where a window pops up on start up and says: This Application has failed to start because MSVCR80.dll was not found. Reinstalling this application may fix the problem. On the bar it says dw20.exe.
If I click ok then another window opens and says: Microsoft .NET Error Reporting Shim has stopped working. A problem caused the program to stop working.....
I do not have Norton and Windows Defender is disabled. I have checked that msvcr80.dll is in x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.42_none_db5f52fb98cb24ad under WinSxS. I have not done anything recently.
I am not very familiar with manifests and all that if that is the problem but anyway help would be appreciated.
Devour
    Dell Inspiron 518
    Intel Dual Core 2.53GHz
    2GB
    ATI Radeon HD 4670 512MB
    Realtek HD
    Dell 20 inch
    250GB, 500GB Seagate
    Dell wired
    Dell wired
    5000 Download 1000 Upload
pooch
Old Dog
1,046
Location
Germany
Devour
Hi Devour, Welcome to the forum.
Do you know what software is failing to start??......dw20.exe is just a fault finding program on Windows computers.
One way to find out would be to disable all autostart programs. If the problem is gone then enable the programs one at a time until the problem returns. You then need to reinstall this one program that is causing the problem.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
47
Hi and thanks Pooch. It seems that the problem has dissapeared for some reason. Very strange. I did nothing and it came and went:sarc:. I was just looking at your specs. LOL! 8GB RAM? 1750GB HD or something. Xtreme Processor. NICE!!!
    Dell Inspiron 518
    2GB
    Realtek HD
    Dell 20 inch
    Dell wired
    Dell wired
