Empty Recycle Bin - Add to Desktop Context Menu
ByLine
How to Add "Empty Recycle Bin" to the Vista Desktop Context Menu
Synopsis
This will show you how to add or remove the Empty Recycle Bin option from the desktop context menu in Vista.
This will show you how to add or remove the Empty Recycle Bin option from the desktop context menu in Vista. By default, Empty Recycle Bin is not in the desktop context menu.
EXAMPLE: Desktop Context Menu without and with "Empty Recycle Bin" added
1. To Add Empty Recycle Bin to Desktop Context Menu
Add_Desktop_Empty_Recycle_Bin.zip
download
B) Go to step 3.​
2. To Remove Empty Recycle Bin to Desktop Context Menu
Remove_Desktop_Empty_Recycle_Bin.zip
download
3. Click on Save, and save the .zip file to the desktop.​
4. Open the .zip file and extract the .reg file to the desktop.​
5. Right click the extracted .reg file and click on Merge.​
6. Click on Run, Continue, Yes, and OK when prompted.​
7. When done, you can delete the downloaded .reg and .zip files if you like.​
  • Add_Desktop_Empty_Recycle_Bin.zip
  • Remove_Desktop_Empty_Recycle_Bin.zip
Kernel
Vista User
Power User
It is a very good idea to setup clean desktop. no need to place recycle bin icon on the desktop.
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
Brink
Staff member
mvp
You're welcome guys. I always like a clean desktop as well. :)
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Hello PCS, and welcome to Vista Forums.
This works perfectly fine on Vista 64-bit, but does not work on Windows 7. Windows 7 questions and issues need to be posted at our sister site Seven Forums instead though.
Sorry. :(
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
