Solved Error 0x80041313 when creating a restore point
Ashanta
Need to fix an issue occured when creating a restore point I got the following error under Vista 32bits:
"The task object version is either unsupported or invalid."
    Amilo Pro v3505
    Intel Core 2 T5300 1.73 Ghz
    1 Gb
    Intel Graphics Media Accelerator Driver for Mobile
    Realteck
MilesAhead
Eclectician
Did you do any Windows updates recently? That's about the only thing I can find on it. If so try restoring to a point before the last update cycle if you have the restore point.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
Last updates installed, dated from end of april 2013.
I know that the automatic restore points were disabled. That's why I'm trying to do it manually before installing a new program ;)
Is it the same to create a restore point on a Safe Mode than on a Normal Mode ?
    Amilo Pro v3505
    1 Gb
    Realteck
Ashanta
Look at this : see attached fileRestore Point.jpg
    Amilo Pro v3505
    1 Gb
    Realteck
MilesAhead
Eclectician
I don't really know. Do you have an external drive? It would be even better to make a system backup image. Macrium Reflect Free and Easus ToDo Backup Free are both very good. There are others also. A good source is www.TheFreeCountry.com
It seems most people with that error are trying to use the Task Scheduler. I didn't see anything other than yours about that error with a restore point.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
I don't understand why Revo Uninstaller can do it a restore point and why I can't do it manually. :huh:
    Amilo Pro v3505
    1 Gb
    Realteck
ilikefree
Try Windows key and R
Type rstrui.exe
See if that opens it and allows you to continue
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Ashanta
The problem is not to restore but to create a restore point.
Type rstrui.exe
    Amilo Pro v3505
    1 Gb
    Realteck
ilikefree
Yes do you not get the option to create a restore point at the bottom of the box that opens?
    LENOVO 64734VM
    15 inch
    External Speakers
Ashanta
    Amilo Pro v3505
    1 Gb
    Realteck
MilesAhead
Eclectician
You could try it programmatically with AutoIt using this Function
AutoIt is a free Windows scripting programming language. It has simple syntax. You can ask on the AutoIt forum if you need help making your first script. The AutoIt installer is small and should go on without problems.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
and what about ERUNT ?
By the way, I have start VSS service and Windows Back Up service, both were stopped, but I still have the same error.
    Amilo Pro v3505
    1 Gb
    Realteck
MilesAhead
Eclectician
You haven't said if you have or have not a Restore Point from before the problem. If so I don't see why you haven't tried it.
I don't see the relavance of ERUNT. It's a registry backup tool. Do you have ERUNT backups? If so I don't know why you aren't trying them instead of doing all this detective work. Seems like heading West to get to the Far East to me.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
I have a few Restore Points as you watched on my previous screenshots, but I don't know if it's before the problem occured.
This is not a new troubles. I noticed this trouble a few months ago, but I don't know exactely the date, that's the problem.
No, my ERUNT backups are from 2012, too old back up.
    Amilo Pro v3505
    1 Gb
    Realteck
MilesAhead
Eclectician
Anyway, if you can run a program that creates a restore point programmatically, it's probably using the function used by the AutoIt program.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
Why it's so hard to fix this issue ? I don't really understand it. Restore to a previous installation, this is not a solution; overall, when I don't know when this troubles began.
    Amilo Pro v3505
    1 Gb
    Realteck
MilesAhead
Eclectician
If you don't know then how do you expect others to? It would seem to me that the last restore point created is the only option. Since the error prevented any from being created afterwards. It's only simple logic.
But you seem to want to have a problem rather than take any action. No one can force you to try something.
I see no point in going on.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ashanta
Ok, I will try it but I don't think so it will fix my issue. Will try with older Restore points, but not the latest ones as this issue is not new and we will see.
Which program can do restore points on demand, low in ressources and memory ?
    Amilo Pro v3505
    1 Gb
    Realteck
Ashanta
I've also the following error from the Event Viewer:
Description: VSS: error querying for the IVssWriterCallback interface. hr : 0x80070005
    Amilo Pro v3505
    1 Gb
    Realteck
