Error 1935 when installing Visual C++ 2008
davehem
I have just bought NFS Hot Pursuit and it needs to install Visual C++ 2008 Redistributable with service pack 1. When tyring to install i get the error which i have added as an attachment.
I have tried removing bits from COMPONENTS on regedit but that didn't work.
Really need some help, this is driving me nuts!!
davehem
Just thought i would add the errors shown in the cbs.log file as well:
2011-01-05 22:43:43, Error CSI 00000030 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7260# from CCSDirectTransaction::PerformChangeAnalysis(...)[gle=0xd0150024]
2011-01-05 22:43:43, Error CSI 00000031 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7259# from CCSDirectTransaction::PrepareForCommit(...)[gle=0xd0150024]
2011-01-05 22:43:43, Error CSI 00000032 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7258# from CCSDirectTransaction::ExamineTransaction(...)[gle=0xd0150024]
2011-01-05 22:43:43, Error CSI 00000033 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7257# from CCSDirectTransaction_IRtlTransaction::ExamineTransaction(...)[gle=0xd0150024]
2011-01-05 22:43:43, Info CSI 00000034 Changelist shadowed missing its manifest - policy.9.0.Microsoft.VC90.MFC, Version = 9.0.21022.8, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:24{12}]"win32-policy", TypeName neutral, PublicKey neutral
2011-01-05 22:43:43, Error CSI [email protected]/1/5:22:43:43.998 (F) d:\longhorn\base\wcp\componentstore\csd_winners.cpp(953): Error STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE originated in function OriginateManifestsMissingError expression: (null)
[gle=0x80004005]
2011-01-05 22:43:46, Error CSI 00000036 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7404# from CCSDirectTransaction::PerformChangeAnalysis(...)[gle=0xd0150024]
2011-01-05 22:43:46, Error CSI 00000037 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7403# from CCSDirectTransaction::PrepareForCommit(...)[gle=0xd0150024]
2011-01-05 22:43:46, Error CSI 00000038 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7402# from CCSDirectTransaction::GenerateComponentChangeList(...)[gle=0xd0150024]
2011-01-05 22:43:46, Error CSI 00000039 (F) STATUS_SXS_TRANSACTION_CLOSURE_INCOMPLETE #7401# from Windows::COM::CPendingTransaction::ExtractInformationFromRtlTransaction(...)[gle=0xd0150024]
2011-01-05 22:43:46, Error CSI 0000003a (F) HRESULT_FROM_WIN32(ERROR_SXS_TRANSACTION_CLOSURE_INCOMPLETE) #7149# from Windows::COM::CPendingTransaction::IStorePendingTransaction_Analyze(...)[gle=0x8007371b]
2011-01-05 22:43:46, Error SXS Analyze Transaction failed with 0x8007371b
Lottiemansion
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
davehem
I have tried installing x64 package and SP1 and feature pack for it was well and these install fine its just just seems to be the x86 version. i have uninstalled all traces of it and reinstalled it straight from microsoft but with no luck.
i really don't want to do a repair install as my pc has vista sp2 and my vista cd is sp1. which means me uninstalling sp2 then doing repair install. i dont know a lot about this so i'd rather avoid it if i can.
Lottiemansion
    40 Meg
niemiro
Banned
Hello!
I will try my very best to fix this error, but I tell you now that it won't be easy, if we ever get it fixed, as there is actually no specific fix yet. Please try to install VC++ 2008 SP1 now, and note down the approximate time you started the install (to the nearest 5 minutes or so, if you can, so I can easily find it in the log, after the rest of this post)
First please run the System Update Readiness Tool. This usually takes 15-30 minutes to complete. See here, download it, and install it. Description of the System Update Readiness Tool for Windows Vista, for Windows Server 2008, for Windows 7, and for Windows Server 2008 R2
Right, now please run steps 1, 2A, 3 (about 15 minutes), 4, 5, and then Step 1 from the top yellow box, but only follow this last one if Integrity Violations were found. Please upload the new sfcdetails.txt from your Desktop. System Files - SFC Command
Now please navigate to C:\Windows\Logs, and copy the CBS folder to your Desktop. Right click on it > Send to > Compressed (zipped) archive. Upload that zip file here please.
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
davehem
Sorry might be being thick here but i have done 1, 2a then 3 is press enter which might take time to finish. Pressing enter just brings up a new command line. have i done something wrong??
niemiro
Banned
Hello!
No worries!
You want to run scannow to scan all files. Have you typed in sfc /scannow before pressing enter? Your Command Line should look exactly like this:
Code:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Richard>sfc /scannow
Beginning system scan.  This process will take some time.
Beginning verification phase of system scan.
Verification 25% complete.
Good luck!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
niemiro
Banned
I have run sfc /scannow but it took about 2 seconds to complete with no violations found. should this have taken longer??
Hello!
Yes, it should have taken much longer. This sounds like it is not your fault in any way, but you have some very bad corruption, which we may/may not be able to fix. Please continue onto the LOGS step.
Thanks!
Richard
P.S. I am going to do a little bit of work, and then bed now. I will look at your logs tomorrow. Thanks for your patience!
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
davehem
Here are the logs. 2011-01-07 20:15:04 should be the start.
Thanks a lot for your help with this. looking forward to hearing your thoughts (good or bad)
Dave
niemiro
Banned
Hello Dave!
Sorry for the delay, normal life got in the way.
You certainly have some sort of bad corruption there. Error 1935 is very often caused by anti-malware software preventing the install. Please temporarily disable all real-time anti-malware tools, in particular Tea-Timer and Webroot.
Good luck!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
