Error Code 19 - HID Compliant Mouse
UchihaJax
8
I know you've probably gotten a hell of a lot of these, and I've tried every solution I could find on this site, along with pretty much a lot of other sites...
But no luck at all, I don't really know how to set this thread out and I apologise for that, but basically my mouse is working, it says it installs correctly, and then doesnt seem to read it correctly.. (code 19)
I've followed countless tutorials and troubleshooted in any way possible...
No luck.
I've poured countless hours into fixing it and I'm fed up and clueless...
Most sites don't even reply or just lazily reply "reformat"...
It's definitely the software/hardware, the mouse is fine.
Any help please?
Thanks in advance
197
Location
FLORIDA
If you're getting this error while the mouse is installed, then basically if the system isn't reading the mouse controller, then I would recommend reinstalling your chipset drivers, which control anything that plugs into the system ( EG>USB, PS2, ETC )
What motherboard do you have?
    Self-Built
    AMD PHENOM X4 9600 BE 2.3GHZ @ 2.46GHZ
    TA790GX 128M AM2+
    8GB OCZ PC6400 800MHZ DDR2 RAM
    NVIDIA GTS 250 1GB VRAM
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    MS WIRELESS DESKTOP 3000
    6MB/s
    Main Machine. Just upgraded my RAM to 8GB. Next task will be to get a new processor for this machine ( 9650 was for my secondary machine )
UchihaJax
8
Oh and I'm not exactly very intelligent with computers... well I am, just not the repairing side.
So basically... no idea what motherboard I have or how to reinstall a chipset driver.
Sorry if I'm stupid, but try to bear with me ><
UchihaJax
8
Btw sorry for double post if thats a rule here.
But it does recognise it, in the device manager / mouse properties, comes up with a ! mark next to it.
But yeah, code 19 error.
http://biosagentplus.com/results.php?ref=01ywrjy&referral=40
There's my specs if that helps.
It recognises other things such as wireless internet... if I plug it into that port
but it doesnt read the mouse.
it does recognise the mouse however... makes the sound, comes up under being plugged in... but is "damaged or not installed correctly"
apparently it was due to an update i re-installed from microsoft... i re-installed the service pack 2 for vista to fix something... but im not sure.
its similar to this: http://www.vistax64.com/vista-general/90895-usb-mouse-hid-compliant-mouse.html
except my device comes under mouse, not other device...
and i tried the recomended solution website for it as well, no luck.
well... ive tried worded tutorials, youtube tutorials... guides from other sites
this is first forum ive actually joined and communicated with though..
so if you guys can help me fix it... kudos
197
Location
FLORIDA
Try this.. This is a legitimate method...
Start>Run>Dxdiag
Allow it to check for unsigned drivers. Copy+Paste the results.
What is the model number of your computer? What brand? If it is a DELL, then what is the Service Tag?
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
UchihaJax
8
System Information
Time of this report: 1/10/2010, 21:41:06
Machine name: JAX-PC
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.090803-2339)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire M3100
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ (2 CPUs), ~2.5GHz
Memory: 2046MB RAM
Page File: 1572MB used, 2779MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
Code:
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: ATI Radeon HD 2400 PRO
     Manufacturer: ATI Technologies Inc.
        Chip type: ATI Radeon Graphics Processor (0x94C3)
         DAC type: Internal DAC(400MHz)
       Device Key: Enum\PCI\VEN_1002&DEV_94C3&SUBSYS_E400174B&REV_00
   Display Memory: 884 MB
 Dedicated Memory: 117 MB
    Shared Memory: 767 MB
     Current Mode: 1024 x 768 (32 bit) (75Hz)
          Monitor: BenQ FP202WA
      Driver Name: atiumdag.dll,atidxx32.dll,atidxx64,atiumdva.cap,atiumd64,atiumd6a,atitmm64
   Driver Version: 8.14.0010.0662 (English)
      DDI Version: 10
   BGRA Supported: Yes
Driver Attributes: Final Retail
 Driver Date/Size: 4/29/2009 01:52:04, 3082752 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp:
Device Identifier: {D7B71EE2-D783-11CF-6D76-0AC4A1C2C535}
        Vendor ID: 0x1002
        Device ID: 0x94C3
        SubSys ID: 0xE400174B
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel: ModeMPEG2_A ModeMPEG2_C
 Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                   {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
Sound Devices
            Description: Speakers (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_105B0E0A&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHDA.sys
         Driver Version: 6.00.0001.5391 (English)
            WHQL Logo'd: Yes
          Date and Size: 3/26/2007 22:18:18, 1761696 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Realtek Digital Output (Realtek High Definition Audio)
 Default Sound Playback: No
 Default Voice Playback: No
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: Yes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: Digital Output Device (HDMI) (High Definition Audio Device)
            Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: HdAudio.sys
         Driver Version: 6.00.6002.18005 (English)
            WHQL Logo'd: Yes
          Date and Size: 4/11/2009 15:43:02, 236544 bytes
            Other Files:
        Driver Provider: Microsoft
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
            Description: Aux (Realtek High Definition Audio)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
            Description: Modem #2 Line Record
  Default Sound Capture: No
  Default Voice Capture: No
            Driver Name:
         Driver Version:
      Driver Attributes:
          Date and Size:
              Cap Flags: 0x1
           Format Flags: 0x0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Microsoft eHome Infrared Transceiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4388
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/11/2009 15:43:16, 196096 bytes
| Driver: usbd.sys, 1/19/2008 16:53:17, 5888 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 1/19/2008 16:49:18, 54784 bytes
| Driver: kbdclass.sys, 1/19/2008 18:41:52, 35384 bytes
+ Microsoft eHome Remote Control Keyboard keys
| Matching Device ID: hid\irdevice&col05
| Service: kbdhid
| Driver: kbdhid.sys, 4/11/2009 15:38:40, 17408 bytes
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\irdevice&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\irdevice&col07
| Service: kbdhid
| Driver: kbd106.dll, 11/2/2006 20:39:43, 6656 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 17:32:52, 53224 bytes
| Driver: sermouse.sys, 1/19/2008 16:49:16, 19968 bytes
| Driver: mouclass.sys, 1/19/2008 18:41:52, 34360 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 19.6 GB
Total Space: 147.8 GB
File System: NTFS
      Model: ST3320820AS ATA Device
      Drive: D:
 Free Space: 132.9 GB
Total Space: 147.5 GB
File System: NTFS
      Drive: E:
      Model: HL-DT-ST DVD-RW_GSA-H41N ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/11/2009 15:39:17, 67072 bytes
System Devices
     Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_0E0A105B&REV_20\4&1B8A4F40&0&0038
   Driver: n/a
     Name: Motorola SM56 Speakerphone Modem
Device ID: PCI\VEN_1057&DEV_3052&SUBSYS_30201057&REV_04\4&35E69562&0&08A4
   Driver: n/a
     Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_0E0A105B&REV_00\4&35E69562&0&30A4
   Driver: C:\Windows\system32\DRIVERS\ohci1394.sys, 6.00.6002.18005 (English), 4/11/2009 15:43:04, 62208 bytes
   Driver: C:\Windows\system32\DRIVERS\1394bus.sys, 6.00.6001.18000 (English), 1/19/2008 16:53:27, 53376 bytes
     Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&18D45AA6&0&C3
   Driver: n/a
     Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&18D45AA6&0&C2
   Driver: n/a
     Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&18D45AA6&0&C1
   Driver: n/a
     Name: AMD HyperTransport(tm) Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&18D45AA6&0&C0
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AA10&SUBSYS_AA10174B&REV_00\4&19466F17&0&0110
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/11/2009 15:42:42, 561152 bytes
     Name: ATI Radeon HD 2400 PRO
Device ID: PCI\VEN_1002&DEV_94C3&SUBSYS_E400174B&REV_00\4&19466F17&0&0010
   Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0899 (English), 4/29/2009 03:31:40, 4491776 bytes
   Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0019 (English), 4/29/2009 01:11:02, 53248 bytes
   Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0662 (English), 4/29/2009 01:52:04, 3082752 bytes
   Driver: C:\Windows\system32\atiumdva.dll, 8.14.0010.0223 (English), 4/29/2009 01:37:06, 4963840 bytes
   Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 4/29/2009 02:06:28, 159744 bytes
   Driver: C:\Windows\system32\atiicdxx.dat, 3/2/2009 20:55:18, 184751 bytes
   Driver: C:\Windows\system32\amdpcom32.dll, 8.14.0010.0023 (English), 4/29/2009 01:25:10, 51712 bytes
   Driver: C:\Windows\system32\atimpc32.dll, 8.14.0010.0023 (English), 4/29/2009 01:25:10, 51712 bytes
   Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1040 (English), 4/29/2009 01:24:36, 163840 bytes
   Driver: C:\Windows\system32\atiumdva.cap, 4/29/2009 01:36:38, 167952 bytes
   Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 4/29/2009 02:05:48, 11776 bytes
   Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1025 (English), 4/29/2009 02:07:34, 176128 bytes
   Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1025 (English), 4/29/2009 02:08:02, 303104 bytes
   Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2553 (English), 4/29/2009 02:06:10, 356352 bytes
   Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0005 (English), 4/29/2009 02:05:56, 278528 bytes
   Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 4/29/2009 02:05:40, 43520 bytes
   Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3405.38053 (English), 4/29/2009 02:08:28, 442368 bytes
   Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8664 (English), 4/29/2009 01:41:58, 11559424 bytes
   Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0283 (English), 4/29/2009 01:21:00, 3293184 bytes
   Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0283 (English), 4/29/2009 01:22:22, 53248 bytes
   Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0283 (English), 4/29/2009 01:22:06, 53248 bytes
   Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 3/3/2009 19:56:00, 118784 bytes
   Driver: C:\Windows\system32\atidxx32.dll, 8.15.0010.0198 (English), 4/29/2009 02:02:56, 2428928 bytes
   Driver: C:\Windows\atiogl.xml, 2/25/2009 08:42:08, 16032 bytes
   Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 2/3/2009 20:52:04, 45056 bytes
   Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 2/18/2009 17:55:22, 294912 bytes
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_7917&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&38
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:55, 149480 bytes
Device ID: PCI\VEN_1002&DEV_7913&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&10
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1002&DEV_7910&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&00
   Driver: n/a
     Name: ATI I/O Communications Processor LPC Controller
Device ID: PCI\VEN_1002&DEV_438D&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&A3
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/19/2008 18:41:14, 16440 bytes
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_438C&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&A1
   Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:49, 14312 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:52, 43496 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:26, 19944 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 17:32:42, 109032 bytes
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_438B&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&9C
   Driver: C:\Windows\system32\drivers\usbohci.sys, 6.00.6002.18005 (English), 4/11/2009 15:42:52, 19456 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18005 (English), 4/11/2009 15:42:57, 226304 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18005 (English), 4/11/2009 15:43:16, 196096 bytes
   Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/19/2008 18:34:25, 15872 bytes
Device ID: PCI\VEN_1002&DEV_438A&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&9B
Device ID: PCI\VEN_1002&DEV_4389&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&9A
Device ID: PCI\VEN_1002&DEV_4388&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&99
Device ID: PCI\VEN_1002&DEV_4387&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&98
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4386&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&9D
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18005 (English), 4/11/2009 15:42:52, 39936 bytes
   Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 20:46:05, 8704 bytes
     Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_0E0A105B&REV_14\3&18D45AA6&0&A0
   Driver: n/a
     Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_00\3&18D45AA6&0&A4
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&A2
Device ID: PCI\VEN_1002&DEV_4380&SUBSYS_0E0A105B&REV_00\3&18D45AA6&0&90
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
CyberLink Demultiplexer(HomeNetwork),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
CyberLink Audio Decoder 0,0x08000000,1,1,PSDMAD.ax,3.05.0000.5309
CyberLink Video/SP Decoder (PCM45),0x00200000,2,3,CLVSD.ax,6.00.0000.1821
PP File Reader (Async.),0x00200000,0,1,PSDReader.ax,2.00.0000.0812
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18005
CyberLink SnapShot Filter,0x00200000,1,0,MCESnapShot.ax,1.00.0003.0026
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8081.0709
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
CyberLink DDR,0x00200000,1,0,MCERender.ax,2.00.0002.0026
IDM Filter,0x00200000,1,1,PSDIDMF.ax,1.00.0000.2207
CyberLink Scene Detect Filter 2,0x00200000,1,1,CLScnDt2.dll,1.01.0000.3202
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.5121
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
CyberLink MPEG-1 Splitter,0x00805000,1,2,PSDM1Splter.ax,2.03.0000.1118
MDR TL MPEG Splitter,0x00200000,1,2,MDTLMSplter.ax,3.01.0000.1220
DV Muxer,0x00400000,0,0,,6.06.6001.18000
CyberLink Push-Mode CLStream,0x00200000,0,1,CLStream(PushMode).ax,1.01.0000.2728
Color Space Converter,0x00400001,1,1,,6.06.6002.18005
CyberLink Audio Spectrum Analyzer(HomeNetwork),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
PDX MPEG-4 Splitter,0x00200000,1,2,PSDM4Splt.ax,1.00.0000.2204
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Cyberlink Dump Dispatch Filter,0x00200000,1,0,PNRDumpDispatch.ax,1.02.0001.2412
DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18005
CyberLink Video Effect (PCM45),0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
CyberLink MPEG-2 Splitter,0x00805000,1,2,PNRM2Splter.ax,2.02.0000.3030
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18005
CyberLink MPEG Video Encoder,0x00200000,1,1,R2DMpgVEnc.ax,5.00.0000.1104
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
CyberLink Audio Decoder (PCM45),0x00200000,1,1,CLAud.ax,6.01.0000.3628
CyberLink MPEG-2 Splitter,0x00805000,1,2,R2DM2Splter.ax,2.02.0000.3128
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,PSDEdtKrn.dll,3.00.0000.1128
CyberLink DV Buffer,0x00200000,2,0,MCEDVBuffer.ax,2.00.0000.1610
IDM Filter,0x00200000,1,1,idmf.ax,1.00.0000.2207
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18005
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,CLMP3Wrap.ax,1.00.0000.0000
CyberLink Audio Decoder (PCM45),0x00200000,1,1,CLAud.ax,6.00.0000.1718
CyberLink Audio Resampler,0x00200000,1,1,R2DAuRsmpl.ax,1.00.0000.2625
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
CyberLink VAudAna Filter,0x00200000,1,0,MDVAudAna.dll,1.01.0000.0826
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6001.18000
CLMSTranscodeSink,0x00200000,1,0,CLMSTranscodeSink.ax,1.00.0000.1427
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6001.18000
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18005
PDX MPEG-4 Video Decoder,0x00200000,1,1,PNRM4Vd.ax,1.05.0000.2018
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6001.18322
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18005
CyberLink Video Regulator,0x00200000,1,1,PNRRgl.ax,2.00.0000.3328
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18005
Cyberlink SubTitle Importor (PCM45),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
PDX MPEG-4 Video Decoder,0x00200000,1,1,PSDM4Vd.ax,1.05.0000.2018
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
CyberLink TL MPEG Splitter,0x00200000,1,2,PSDTLMSplter.ax,3.00.0000.1006
CyberLink TimeStretch Filter (CES),0x00200000,1,1,PNRAuts.ax,1.00.0000.2212
CyberLink Video/SP Decoder,0x00200000,2,3,CLVSD.ax,6.00.0000.2130
CyberLink Video/SP Decoder (PCM45),0x00200000,2,3,CLVSD.ax,6.00.0000.3402
CyberLink Double Pin Tee,0x00200000,1,2,MCEDoubleTee.ax,1.00.0000.1224
CyberLink TL MPEG-1 Splitter,0x00804500,1,2,MDTLM1Splter.ax,2.02.0000.2213
MPV Decoder Filter,0x40000002,1,1,Mpeg2DecFilter.ax,1.00.0000.0003
CyberLink Line21 Decoder Filter (PCM45),0x00200000,0,2,CLLine21.ax,4.00.0000.7205
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18005
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
muvee HXImage Filter,0x00200000,1,1,HXImageFilter.ax,4.00.0004.0000
CyberLink MPEG Decoder,0x005fff00,2,3,PNRMVD.ax,5.00.0000.0929
CyberLink Video Regulator,0x00200000,1,1,PSDRgl.ax,2.00.0000.3328
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
PP File Reader (Async.),0x00200000,0,1,R2DReader.ax,2.00.0000.0812
Cyberlink Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
CyberLink WMV/WMA Demultiplexer,0x00600000,1,2,CLWMFDemux.ax,1.00.0000.1302
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
CyberLink MPEG Video Encoder,0x00200000,1,1,PSDVidEnc.ax,6.00.0001.2130
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18005
AVS Video Out,0x00200000,0,1,AVSVideoOutFilter3.ax,1.00.0000.0228
CyberLink MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,6.01.0001.1805
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18005
CyberLink Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1220
CyberLink Audio Decoder,0x00200000,1,1,claud.ax,6.01.0000.3628
FLV File Source,0x00200000,0,2,Flv.ax,2006.02.0028.0001
CyberLink DVD Navigator (PCM45),0x00600000,0,3,CLNavX.ax,6.00.0000.3230
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.3328
DV Splitter,0x00600000,1,2,,6.06.6001.18000
CyberLink Video/SP Decoder,0x00200000,2,3,CLVSD.ax,6.00.0000.3313
CyberLink TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.02.0000.2219
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18005
CyberLink MPEG Muxer,0x00200000,2,1,MCEMpgMux.ax,4.00.0000.2221
PDX MPEG-4 Splitter,0x00200000,1,2,PNRM4Splt.ax,1.00.0000.2204
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.0907
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
CyberLink Audio Noise Reduction,0x00200000,1,1,PSDAuNRWrapper.ax,2.00.0000.1017
Cyberlink Video Regulator,0x00200000,1,1,PSDResample.ax,2.05.0000.1818
CyberLink DV Filter,0x00200000,1,1,MCEDVTCR.ax,2.01.0000.2810
SampleGrabber Filter,0x00200000,1,1,SampleGrabber.ax,9.00.0000.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
IDM Filter,0x00200000,1,1,PNRIDMF.ax,1.00.0000.2207
CyberLink Audio Encoder,0x00200000,2,0,MDAudEnc.ax,2.00.0000.2927
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
Cyberlink Video Regulator,0x00200000,1,1,MCEResample.ax,2.05.0000.1818
PP File Reader (Async.),0x00200000,0,1,PNRReader.ax,2.00.0000.0812
CyberLink Video/SP Decoder,0x00200001,2,3,MDVSD.ax,6.00.0000.2130
FMScrCap Source,0x00200000,0,1,FMScrCap.ax,1.00.0000.0001
CyberLink AudAna Filter,0x00200000,1,0,MDAudAna.dll,2.00.0000.2708
CyberLink YUY2 DeInterlace,0x00200000,1,1,MCEDitlYUY2.ax,2.01.0000.1715
CyberLink TimeStretch Filter (CES),0x00200000,1,1,PSDAuts.ax,1.00.0000.2212
CyberLink Audio Effect (PCM45),0x00200000,1,1,claudfx.ax,6.00.0000.1223
CyberLink MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.00.0000.3131
ACM Wrapper,0x00600000,1,1,,6.06.6002.18005
PDR MPEG-4 Muxer,0x00200000,1,1,PNRM4Muxer.ax,1.00.0000.1023
Video Renderer,0x00800001,1,0,,6.06.6002.18005
CyberLink MPEG Splitter(Scramble),0x00200000,1,2,CLSplter.ax,3.01.0000.1508
Cyberlink Dump Filter,0x00200000,1,0,PNRDump.ax,3.00.0000.5303
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6001.18000
CyberLink TimeStretch Filter (PCM45),0x00200000,1,1,clauts.ax,1.00.0000.2927
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6002.18005
Video Port Manager,0x00600000,2,1,,6.06.6002.18005
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,8.02.0000.0026
R2D Dump Dispatch Filter,0x00200000,1,0,R2DDumpDispatch.ax,1.02.0001.2412
CyberLink Demultiplexer (PCM45),0x00400000,1,0,CLDemuxer.ax,1.00.0000.2728
Video Renderer,0x00400000,1,0,,6.06.6002.18005
CyberLink VidAna Filter,0x00200000,1,1,MDVidAna.dll,1.00.0000.0126
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
CyberLink Audio Resampler,0x00200000,1,1,PSDAuRsmpl.ax,1.00.0000.2625
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
PDX MPEG1/2 Video Decoder,0x00200000,2,3,PSDVsd.ax,6.00.0000.2130
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.03.0000.0085
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
Cyberlink Video Regulator,0x00200000,1,1,PNRResample.ax,2.05.0000.1818
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
PDX Audio Effect,0x00200000,1,1,PNRAudfx.ax,6.00.0000.1223
CyberLink Demultiplexer (PCM45),0x00200000,1,0,CLDemuxer.ax,1.00.0000.5101
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
CyberLink Audio Wizard (PCM45),0x00200001,1,1,CLAudWizard.ax,1.00.0000.1116
CyberLink Audio Decoder,0x00200000,1,1,PSDAud.ax,6.00.0000.2114
CyberLink MPEG Video Encoder,0x00200000,1,1,PNRVidEnc.ax,6.00.0001.2130
Cyberlink Dump Filter,0x00200000,1,0,MCEDump.ax,3.00.0000.3322
CyberLink DVD Navigator (PCM45),0x00200000,0,3,CLNavX.ax,6.00.0000.3614
CyberLink Demultiplexer,0x00200000,1,0,PNRDemuxer.ax,1.00.0000.3319
CyberLink Audio Decoder,0x00200001,1,1,MDAUD.ax,6.00.0000.2610
Cyberlink Dump Filter,0x00200000,1,0,CLDump.ax,4.00.0000.6714
PDX MPEG1/2 Video Decoder,0x00200000,2,3,PNRVsd.ax,6.00.0000.2130
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.2026
Cyberlink Dump Dispatch Filter,0x00200000,1,0,MDDumpDispatch.ax,1.02.0001.2412
PDX H.264/AVC Decoder,0x00200000,2,3,PNR264dec.ax,1.05.0000.0923
CyberLink MPEG Video Encoder,0x00200000,1,1,MDVidEnc.ax,6.00.0001.2226
CyberLink MPEG Video Decoder,0x00200000,2,3,MCEmmv.ax,4.00.0000.3013
PP M2V Writer,0x00200000,1,0,PNRM2VWriter.ax,1.03.0000.0705
Honestech VCD/SVCD Encoder,0x00200000,2,0,htvcdsvcd70.ax,1.00.0000.0000
IDM Filter,0x00200000,1,1,MDIDMF.ax,1.00.0000.3909
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,,6.06.6002.18005
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
CyberLink Video/SP Decoder (ShEX),0x00200000,2,3,CLImageVSD.ax,6.00.0000.3202
Cyberlink Gate Filter,0x00200000,1,1,MCEGate.ax,1.00.0000.0001
Overlay Mixer2,0x00200000,1,1,,6.06.6002.18005
CyberLink Audio Encoder,0x00601000,2,0,PSDAudEnc.ax,2.00.0000.2927
CyberLink Audio Null Renderer Filter,0x00200000,1,0,MDAudioNullRenderer.dll,1.00.0000.0310
PP M2V Writer,0x00200000,1,0,R2DM2VWriter.ax,1.03.0000.0910
DivX MKV Demux,0x00200000,0,1,DMFSource.ax,1.00.0001.0004
CyberLink MPEG Muxer,0x00200000,2,1,PNRMpgMux.ax,5.00.0000.2211
AC3Filter,0x40000000,1,1,ac3filter.cpl,1.00.0001.0000
AVI Draw,0x00600064,9,1,,6.06.6002.18005
Cyberlink Dump Filter,0x00200000,1,0,PSDDump.ax,3.00.0000.5303
muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,4.00.0004.0000
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,4.00.0004.0000
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
CyberLink Audio Decoder 0,0x08000000,1,1,PNRMAD.ax,3.05.0000.5309
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
CyberLink MPEG Muxer,0x00200000,2,1,MDMpgMux.ax,5.00.0000.2211
PDR MPEG-4 Muxer,0x00200000,1,1,PSDM4Muxer.ax,1.00.0000.1023
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18005
Record Queue,0x00200000,1,1,WMM2FILT.dll,
Cyberlink Dump Filter,0x00200000,1,0,MDDump.ax,3.00.0000.5303
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.3207
CyberLink MPEG Muxer,0x00200000,2,1,CL_MS_MpgMux.ax,5.00.0000.2109
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,CLEdtKrn.dll,3.00.0000.1830
Cyberlink Dump Dispatch Filter,0x00200000,1,0,PSDDumpDispatch.ax,1.02.0001.2412
CyberLink MPEG-1 Splitter,0x00805000,1,2,PNRM1Splter.ax,2.02.0000.3030
PDX Audio Effect,0x00200000,1,1,PSDAudfx.ax,6.00.0000.1223
CyberLink TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.18005
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.18005
CyberLink Video Stabilizer,0x00200000,1,1,CLVideoStabilizer.ax,1.00.0000.1017
CyberLink Demultiplexer,0x00200000,1,0,MDDemuxer.ax,1.00.0000.3823
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
CyberLink Video/SP Decoder,0x00200000,2,3,MCEVSD.ax,6.00.0000.2130
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6001.18000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
PP WAV Dest,0x00200000,0,0,CLWavDest.ax,1.00.0000.0002
CyberLink Video/SP Decoder (ShEX),0x005ffc18,2,3,CLImageVSD.ax,6.00.0000.1625
CyberLink Audio Decoder(HomeNetwork),0x00200000,1,1,CLAud.ax,6.01.0000.3613
CyberLink Audio Resampler,0x00200000,1,1,ClAuRsmpl.ax,2.00.0000.0519
CyberLink Audio Encoder,0x00200000,2,0,R2DAudEnc.ax,2.00.0000.2927
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6001.18000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.AX,5.00.0000.0912
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,6.06.6002.18005
CyberLink Video Effect,0x00200000,1,1,PSDVidFx.ax,1.00.0000.2030
AVI Decompressor,0x00600000,1,1,,6.06.6002.18005
R2D Video Decoder,0x00200000,2,3,R2DGereralVSD.ax,6.00.0000.2214
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
CyberLink AudioCD Filter (PCM45),0x00600000,0,1,CLAudioCD.AX,5.00.0000.2512
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,2.00.0000.1228
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.4305
CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.2030
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18005
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
CyberLink MPEG-1 Splitter,0x00805000,1,2,R2DM1Splter.ax,2.02.0000.3128
CyberLink MPEG Muxer,0x00200000,2,1,PSDMpgMux.ax,5.00.0000.2211
Wave Parser,0x00400000,1,1,,6.06.6002.18005
MIDI Parser,0x00400000,1,1,,6.06.6002.18005
Multi-file Parser,0x00400000,1,1,,6.06.6002.18005
File stream renderer,0x00400000,1,1,,6.06.6002.18005
IDM Filter,0x00200000,1,1,idmf.ax,1.00.0000.3909
CyberLink M2V Writer,0x00200000,1,0,PSDM2VWriter.ax,1.03.0000.2017
Cyberlink Sub-Picture Filter,0x00200000,1,1,PSDSubPic.ax,3.00.0000.0728
CyberLink Audio Resampler,0x00200000,1,1,PNRAuRsmpl.ax,1.00.0000.2625
CyberLink Video Stabilizer,0x00200000,1,1,PNRVideoStabilizer.ax,1.00.0000.1014
CyberLink MPEG Decoder,0x005fff00,2,3,PSDMVD.ax,5.00.0000.0929
CyberLink TL MPEG Splitter,0x00200000,1,2,PNRTLMSplter.ax,3.00.0000.1006
Cyberlink Sub-Picture Filter,0x00200000,1,1,PNRSubPic.ax,3.00.0000.0728
CyberLink MPEG Decoder,0x005fff00,2,3,MDMVD.ax,5.00.0000.0929
CyberLink Demultiplexer,0x00200000,1,0,PSDDemuxer.ax,1.00.0000.3319
PDX H.264/AVC Decoder,0x00200000,2,3,PSD264dec.ax,1.05.0000.0923
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
CyberLink TL MPEG-2 Splitter,0x00804500,1,2,MDTLM2Splter.ax,2.02.0000.2213
CyberLink TimeStretch Filter,0x00200000,1,1,clauts.ax,1.00.0000.4024
FMAudioPatch,0x00200000,1,1,FMAudioPatch.ax,1.00.0002.0001
CyberLink Video/SP Decoder (ShEX),0x00200000,2,3,CLImageVSD.ax,6.00.0000.1625
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
CyberLink Audio Resampler,0x00200000,1,1,MDAuRsmpl.ax,1.00.0000.2625
AVI Mux,0x00200000,1,0,,6.06.6001.18000
CyberLink Video Stabilizer,0x00200000,1,1,PSDVideoStabilizer.ax,1.00.0000.1017
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18005
File Source (Async.),0x00400000,0,1,,6.06.6002.18005
File Source (URL),0x00400000,0,1,,6.06.6002.18005
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
CyberLink Video Effect,0x00200000,1,1,PNRVidFx.ax,1.00.0000.2030
CyberLink Line21 Decoder Filter (PCM45),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,PNREdtKrn.dll,3.00.0000.1014
CyberLink MPEG-2 Splitter,0x00805000,1,2,PSDM2Splter.ax,2.03.0000.1118
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
R2D Audio Decoder,0x00200000,1,1,CLAud.ax,6.00.0000.2206
CyberLink Audio Noise Reduction,0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1805
CyberLink Audio Noise Reduction,0x00200000,1,1,PNRAuNRWrapper.ax,2.00.0000.1011
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.1928
CyberLink Audio Noise Reduction,0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1017
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Cyberlink Streamming Filter,0x00200000,0,1,CLStream.ax,1.01.0000.2323
CyberLink Audio Decoder,0x00200000,1,1,PNRAud.ax,6.00.0000.2114
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18005
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18005
CyberLink Audio Encoder,0x00601000,2,0,PNRAudEnc.ax,2.00.0000.2927
CyberLink Audio Effect,0x00200000,1,1,CLAudFx.ax,6.00.0000.2731
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
WDM Streaming Data Transforms:
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18005
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
DivX® 6.8 Codec (2 Logical CPUs),0x00200000,1,1,,6.06.6001.18000
FM Screen Capture Codec,0x00200000,1,1,,6.06.6001.18000
Logitech Video (I420),0x00200000,1,1,,6.06.6001.18000
Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
DivX® 6.8 YV12 Decoder,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,,6.06.6002.18005
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,,6.06.6002.18005
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,,6.06.6002.18005
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,,6.06.6002.18005
IMA ADPCM,0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode1),0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode2),0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode3),0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode1+),0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode2+),0x00200000,1,1,,6.06.6002.18005
Ogg Vorbis (mode3+),0x00200000,1,1,,6.06.6002.18005
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18005
GSM 6.10,0x00200000,1,1,,6.06.6002.18005
Messenger Audio Codec,0x00200000,1,1,,6.06.6002.18005
CCITT A-Law,0x00200000,1,1,,6.06.6002.18005
CCITT u-Law,0x00200000,1,1,,6.06.6002.18005
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18005
Audio Capture Sources:
Aux (Realtek High Definition Au,0x00200000,0,0,,6.06.6001.18000
Modem #2 Line Record,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18005
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18005
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
HD Audio HDMI out,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
Realtek HDA SPDIF Out,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18005
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6001.18000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18005
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18005
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18005
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18005
CyberLink Audio Renderer (PCM45),0x00200000,1,0,CLADR.ax,6.00.0000.1727
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18005
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18005
Digital Output Device (HDMI) (H,0x00200000,1,0,,6.06.6002.18005
DirectSound: Digital Output Device (HDMI) (High Definition Audio Device),0x00200000,1,0,,6.06.6002.18005
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18005
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18005
Modem #2 Line Playback,0x00200000,1,0,,6.06.6002.18005
Realtek Digital Output (Realtek,0x00200000,1,0,,6.06.6002.18005
UchihaJax
8
System Information
Memory: 2046MB RAM
the other data, i posted it but waiting for a moderator to approve... if its needed.
197
Location
FLORIDA
#8
Chipset for your system is AMD 690V + SB600. Hang on. Looking for drivers for your chipset. When I find them I will post a link so you can download. Few minutes please :)
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
197
Location
FLORIDA
#9
ATI Catalystâ„¢ Legacy Display Driver
This is the chipset drivers for your motherboard- Mind not that it says it is a display driver- this is actually your chipset, and the latest drivers. It's near the bottom of the page. About 100MB, if you download it and install, and your issue is not resolved let me know :)
Also, try checking for Windows Updates - There is a hotfix for USB Mice problems in Service Pack 2 if you don't already have that installed. Good luck.
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
UchihaJax
8
#10
Sorry I didn't see this earlier, couldn't get access to a computer, but now I'm using an iPod as an air mouse, so yeah, I'm dling the chipset as you recommended as we speak, I'll update you if it works or not, thanks :p
EDIT: I installed the chipset and restarted, no luck unfortunately ;\
any chance you have msn or something similar we could talk on?
im not trying to rush you but just to save each other coming back here every day for a long time :p
197
Location
FLORIDA
#11
I do have AIM.. PM me and I will provide you with the S/N.
Also have a Yahoo!. My problem is I'm working 11:30AM - 8:30PM or later if I go for OT.
I am able to post on this forum at work intermittently.. I cannot, however access chat. - This is a very strange issue you are having - If there are any free Remote Access tools I'd be more than happy to assist you with your issue. But I am unsure of any. Speaking of which - I'm going to bed now. It's 3:00AM.
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
UchihaJax
8
#12
I have TeamViewer, that's about it I think, I can download any other program if that makes it easier.
Uh, not sure if I have Yahoo.. or at least can't remember my ID.
I'll make a new one so its easier for us to talk...
I haven't had a working mouse in weeks lmao.. so frustrating ><
But forums is fine until then.
197
Location
FLORIDA
#13
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
GKahn
15
#14
could I suggest a freeware that could help you identify that?
If yes, Piriform - Speccy
if not, I would back up the person who wrote under your post ( Infinite excuses, I did not have time to look at your name )
Just simply reinstall the motherboard.
here are a few tips for you:
if it's a laptop:
Turn it upside down and try to find the model number
once you do that, go to the manufacturer's website and look up your model number in the drivers&downloads section of their website
then just simply download the chipset software installation file and you should be all set!
If it's a desktop:
*This requires opening the machine itself, make sure it's powered off before following ANY steps*
1: Open the computer
2: Identify your motherboard (Intel, acer, etc)
3: search for the model number (usually it's very close to the logo)
4: go to your motherboard's manufacturer website and look it up
5: download the software installation file and you should be all set!
Best of luck!! :)
-GKahn
    Toshiba Qosmio
    Intel Mobile Core 2 Duo P7350 @ 2.00 GHz
    TOSHIBA KSRAA (U2E1)
    4.0 Hyundai Electronics Dual-Channel DDR3 @ 533 MHz
    NVIDIA GeForce 9700M GTS 2304MB
    Realtek High definition Audio
    Generic PnP Monitor
    120GB TOSHIBA MG1234GSX
    250GB TOSHIBA MK2552GSX
    n/a
    n/a
    n/a
    n/a
    n/a
    Wireless
    A sweet Gaming Laptop from Toshiba
197
Location
FLORIDA
#16
This issue is being worked on via Remote Access via TeamViewer. Come down to needing to reinstall Windows - Luckily hes got a backup but I am going to need to burn a Driver DVD and a OS DVD!
But hes getting an upgrade to 64-bit :)
    Self-Built
    TA790GX 128M AM2+
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    6MB/s
