Solved Error Code 57 for update KB951847
Had to F11 my 4 year old desktop (Vista 32bit by HP) then reinstall 90+ Windows Updates. Cannot install the last update which is preventing me from updating to IE9.
Have tried some of the past suggestions I"ve seen on-line to correct this, but they haven't worked.
The update is "Microsoft.NET Framework 3.5 Service Pack 1 and .NET Framework 3.5 Family Update (KB951847)x86".
All I have presently for programs installed is "Microsoft.NET Framemaker 1.1".
Microsoft Fix-it it didn't help nor did trying to install it in a safe mode.
Is the problem that I have only Framemaker 1.1 installed and we're trying to install Framemaker 3.5?
Should I try to manually install Framemaker 2.0, then 3.0 before re-running the 3.5 update??
Any help would be appreciated.
Thanks
    Hewlett-Packard Co Model SR5210NX
    Intel(R) Celeron(R)CPU [email protected] 1.60GHz
    unknown
    2039 MB
    unknown
    unknown
    HPw1907
After waiting about 24 hours and about 275 views, I guess there's no "technical expertise" out there who can help me? :>((
    unknown
    2039 MB
    unknown
    unknown
    HPw1907
Solved.................................by Hewlett-Packard technical support no less.
    unknown
    2039 MB
    unknown
    unknown
    HPw1907
