I have been having lots of problems with my pc for the last 2 and a half months. First my processor's cooling fan died and my computer would go to a black screen telling me it was going to shut off automatically and that the fan needed replacing. Replaced with the same model fan and heatsink computer booted back up again normally. Then a month later I began noticing my pc slowing down a bit during boot up. It was also beginning to slow down while opening up folders and minimizing/opening windows. Until it took too long that i powered it off manually then thats when it began to boot up the black screen for me to boot system repair. So from this point on I would boot up my pc and it would tell me to boot up system repair which i did otherwise there was no way i was going to boot up my windows desktop.
As this went on load times were looong and i became impatient and would manually turn off and on only to make things worse. I then decided to boot up Diagnostics Tools which should everything passed except for my HDD. I would get warning signs telling me to make sure the connectors on my hard drive were in correctly and what not but atleast I was able to boot up windows to my desktop. I tried to do a system restore and restored it to a month earlier but after still having the same issues i decided to undo the system restore and thats when the cause of the state of where i am with my pc began.
Undoing the system restore took so long that i left my pc on for hours and it still showed like it was in progress. So being that i noticed the time in the desktop froze (iirc) i rebooted my pc again manually this time I made it worse. The Diagnostic Tool then reported the test on my hard drive as error code BIOHD-8 telling me that it failed a SMART test and to backup my stuff. No longer does my pc boot system repair. Now i have to wait a while and it either boots up Recovery Manager asking me if i would like to restore the factory default image or it just crashes to a blue screen. I tried a SMART test scan from the bios for my hard drive and a few tries i get both passed and failed results.
So now when i boot up my pc after a slow booting up process it either opens up Recovery Manager or crashes to a blue screen. I have took pictures on my phone of the Diagnostic tools test results that i was getting and i took one of the blue screen. If it helps to upload what it says on the blue screen please let me know if i should upload it to a image hosting site to put it on here for you guys to see what it is. Hopefully that may help me get somewhere with this issue.
The main question I would like answered positively is if it's possible i may be able to recover my files and documents via an external hdd enclosure on a new working pc? Since my pc can still be able to open up Recovery Manager from my hard drive after a long booting process which is INSIDE the factory image partition on my hard drive along with the other partitions which contains all my files and data etc.
P.S. If this thread belongs on another section of the forum i apologize as i am quite new here and dont know exactly where all posts belong.
- HP Pavilion Slimline s3500f desktop pc
- AMD Athlon 64 X2 5400+ 2.8 Ghz Dual Core Processor
- M2N61-AR rev.1.2 Asus
- 4GB DDR2 SDRAM
- Graphics Card(s)
- Integrated Nvidia Geforce 6150SE nforce 430 L2 Cache 1.0MB
- Integrated Realtek ALC888S 6 channel HD Audio
- VGA and DVI widescreen LCD Monitor
- 640 x 480 - 60Hz
- 500GB Serial ATA-300 3.5" 7200.0 rpm model:ST3500620AS
SuperMulti 16X DVD(+/-)R/RW 12X RAM (+/-) R DL LightScribe SATA drive model:ATAPI DVD A DH16A6L
- PSU
- 160W
- Case
- Slimline
- Cooling
- Amatech Copper Base/Aluminum Heat Sink & 2.75" Fan 4-pin con
- HP PS/2 multimedia keyboard
- HP PS/2 optical mouse
- Cable High-Speed Broadband
