Error message relating to sending message- HELP PLEASE!
raphaella
The connection to the server has failed. Account: '67.228.224.122 (1)', Server: '67.228.224.122', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
ABOVE is the error message I am getting using Windows Mail- I can't seem to send or set up my account properly, even though it seems I have entered all the correct information.
Please help if you can.
CyberZeus
Hi and welcome to Vista Forums!
Are you using a software Firewall or hardware Firewall that block TCP port 110?
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    [email protected]@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Optical
    Logitech Cordless Desktop EX 100
    8192 kbps / 640 kbps
Alex95
What's your antivirus program?
    HP 6730s
    Intel Core 2 Duo T5670 @ 1.80 ghz 4 mb L2 Cache
    2 GB Ram DDR2
    Intel 4500MHD 128 MB own ram, 796 shared
    HD Audio Output
    1280x800 max on the laptop (1920x1080 on Full Hd Screen :) )
    150 Gb Toshiba 7200 rpm
    7 Mega download, 1 mega upload
Alex95
I remember free avg does not have any kind of firewall, correct me if i'm wrong. Maybe Windows Firewall is blocking Windows Mail. Follow these steps:
1) Start, Control Panel
2)Protection
3)Allow Program With Windows Firewall
4)Look there and see if there is the check at "Windows Mail"
If there's not, check it.
    HP 6730s
    2 GB Ram DDR2
    HD Audio Output
