Error messages after login
Trying to instal it again isn't working...the thing is that the screen turns blue and says there's something wrong with my pc so it has to turn it off...any suggestions on what i should do?
    Dell Vostro 1510
oh, and the other thing is that the disk doesn't start by itself, i ahve to go to start, click computer and click the disk, but everything works the same way u dicribed
    Dell Vostro 1510
ok, sorry for all the messages, but it, and now it says it was unable to create the required installation folder C:\WINDOWS.~BT. An existing file or folder of this name could not be deleted...does this mean i can't reinstal my computer?That i need to buy another one or something?
    Dell Vostro 1510
I think it's because the disc has stopped turning...i don't hear it moving...and maybe i shouldn't have chose use the internet if my computer can't use internet right now...
    Dell Vostro 1510
The disc is damaged, see if you can clean it, or borrow a friends cd and use your cd key
and try to reinstall it from there
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array 3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
if you are getting blue screen check your RAM, are you using SATA or IDE hard drive.. if you are using SATA make sure you setup the SATA in bios or do do it while installing the OS... You need to press F6 then load the SATA drive on an external flooy drive.. can assist you more in that.. but here think more the problem can be a faulty RAM
if you are getting blue screen check your RAM, are you using SATA or IDE hard drive.. if you are using SATA make sure you setup the SATA in bios or do do it while installing the OS... You need to press F6 then load the SATA drive on an external flooy drive.. can assist you more in that.. but here think more the problem can be a faulty RAM , or make sure you format the volume before installing the windows..
Regards
No you do not need to buy another one william. restart your pc with the vista disc in. We are trying to install vista before you login. It is important you do it this way because windows will not install over another installation if you are logged into.
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
ok, i got everything re installed, but now i need to get my internet working and all the other stuff working...the problem with my internet is that it keeps saying it can't find any wireless networks (my computer is a laptop) and when i try to fix it, it says Realtek RTL8168/8111 Family PCI-Gigabit Ethernet NIC (NDIS 6.0) has stopped working, and now i'm looking at it and it really is nt working...do you guys know how to fix it?(btw, can u say it without the short forms, sometimes i don't understand and i have to post again and wait)
    Dell Vostro 1510
There is also Standard VGA Graphics Adapter, Mass Storage Controller, Network Controller and Video Controller not working
    Dell Vostro 1510
get a USB if you are on another computer and go to your laptop's website.
You are looking to download drivers for your laptop get your model name, might be underneath the laptop.
drivers are what lets your hardware, in this case the wireless adapter talk to your computer so your computer can tell it what to do, without this your pc is just going WTF is that thing stuck into me!!??
so download ALL the drivers, all the software, firmware and install it on the laptop. everything should work from there
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
Another problem...it says i need to be a member in order to save the files...so, i click register and personalize, then i enter everything...correctly...then, it says please enter a valid phone number...and i know that i put in the right phone number...maybe it's because i live in Canada and not the US???What should i do now?
    Dell Vostro 1510
or you could always give them a fake US number, just search for some corporations number
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
just copy the files from where they are saved to. and drag them onto the usb.
to find them there are a few options, but to be quick and easy just click on file and then save as in internet explorer
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
You need to install their drivers.. do you have the cds for thed drivers.. if not you need to download them.. search for the right model and compatible with your OS
Ashvin its already done, he's been PMing me and its all sorted I got him the website and what to download.
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
speaking of problems like this i keep getting "windows explorer has encountered an error and needs to restart" every 3 seconds (literally) i f i try to view my desktop how can i stop this?? i have tried turning off dep altogether but that only solves my other problem which was with COM Surrogate...
    Emachines
    AMD Semperon
    NVIDA GeForce 6100 nForce 405
    3.00 GB
    7mb
sounds like something is on your pc that shouldnt be. Try a system restore, if that is "corrupt" normally its a virus. Reformat dude
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
