Eset AV and service pack 2 issues , workarounds
archie123
I Tunes hates Me
Anyone like me having issues with Esets smart security or AV after service pack 2 there are some workarounds , although the final one suggested seems to the best way to go...........uninstall 4 and install Ver 3 :p
ESET Knowledgebase - Why does my Protection status icon turn red after installing Service Pack 2 for Microsoft Windows Vista or Windows Server 2008? (4.0)
the issue is worse for me as it when its playing up it also takes me offline :sarc: a few restarts normally solves the issue but its a pain
Service pack 2 has been in beta for months , why the hell they didnt sort it before now is anyones guess , looking around it seems eset is loosing customers by the bucketload because of this and other issues with ver 3 and 4
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM,
    WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
pretty much the same thing happened to me!! but i was stuck in a loop it after rebbot it started to install phase 3 of 3 then when it got to 33% my pc would reboot!! did it for 2 hours before i assumed summat was wrong , i ended up reformatting.
that said i did reinstall eset after reformat , even before i installed SP1 and all went well the second time
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
