Eset scanner
william gunkel
Preacher Man
I went to download the Eset scanner and after installing the active X control I got the message that I don't have the Admin. rights. Can I just right click on the IE icon and run it as Admin. or do I need to do something else. Also how do you turn off the AVG Internet Security to run a different anti-virus and then turn it back on. Comments welcome.
    H P Pavilion s3120n
    AMD Athlon 64X2 Dual Core Processor 4200+ 2.20GHz
    M2Nc51-AR
    Ram 2.0 GB
    NVIDIA GeForce 6150 LE Graphis
    Realtex
    ViewSonic VX2035WM
    1680X1050 pixels
    320GB 7200RPM Serial ATA
    AC Bel Model#PC6012
    fan
    PS2
    PS2
    10 down 1 up
    Computer has had the motherboard, power pak and tv tuner replaced. Using HP Deskjet F440 Printer, and IE9.
swarfega
da Cleaner
Vista Pro
you could try as you suggested, opening IE using run as admin. To turn off avg you go into its control panel. Theres an option in there to turn it off (not using it atm so cant be more specific).
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0
    WD Raptor 36gb
    3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
