Explorer stops working even in Safe Mode
dandeeny
Have uploaded URL for my system specification page. In case this fails, my machine is an Acer Aspire 5633WLMi, 160 GB hard Drive (55 GB free), 2 GB RAM, loaded with OEM pre-installed Vista Home Premium (updated by now to SP2). System is 3.5 years old.
Early in its operating life the problem started and persists to this day - even in Safe Mode.
When I attempt to save a Window-created file (created using notepad, wordpad or other Windows program) to my hard drive or external flash drive, explorer crashes within 2 secs of clicking on
HTML:
Computer
in the file tree in the left hand pane of the explorer window. Peculiarly the program does not crash with the same invariable consistency if I click on the
expand directory
symbol to the left of the computer icon.
I am at a loss and would very much like NOT to have to re-install Vista.
Can anyone help ?
Dan :cry:
    Acer Aspire 5633 WLMi
    Intel Core 2 Duo T5500 (1.66 GHz/2M)
    2.0 GB
    Mobile Intel 945 Express Chipset
    Realtex High Definition Audio
    1280 X 800
    160 GB
americancritic
Hello and welcome to the forum.
First all all did you make a restore point before downloading anything to your computer...
Plus is your computer a laptop or desktop...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
dandeeny
Hi AmericanCritic.
No. This new Notebook computer was my first experience of using Windows Vista. It was acquired as a second,
computer and I was not very familiar with restore points or the restore process at that time. What can I read into the fact that the problem persists in Safe Mode (with no network support) ?
Dan
    2.0 GB
    1280 X 800
    160 GB
kesume
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
americancritic
Hello
Follow Kesume's suggestion first then If I were you I would do the following...
1. Run a full updated virus scan using your internet security...
2. Run a full scan using malwarebytes, free version..Malwarebytes
If they both come back with no problems then lets do a sfc scan to see if it will fix it's self.
1. Click start...
2. Type cmd in the search box...
3. When the pop up list comes up go to the top and Right click on cmd.exe and run as adminstrator...
4. When the command box opens then type in sfc /scannow notice there is a space between the sfc and the forward slash. When the scan is done if there are any errors then run it 3 more time as it fix's more each time you run it, also here is the tutorial for doing the sfc.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
