Explorer works, but Firefox doesn't
Metalanca
I recently had my computer fixed, and when I got it back, Internet explorer works, though firefox somehow can't connect.
Also (Not sure if it's relevent, but) i tried to install Java, but it says It couldnt download with the current connection settings. I tried allowing firefox through my windows firewall, but it's still not working. I'm pretty sure I don't have any other firewalls.
Any help would be appriciated.
johngalt
Antidisestablishmentarianist
Hi, Metalanca, and welcome to the forums.
You can download JAVA through IE - but have you tried either running Firefox in Safe Mode and / or creating a new profile and / or reinstalling Fx?
And you need to be a *lot* more patient - 4 hours is not nearly enough time to get impatient - 4 days, maybe, 4 hours, no.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Metalanca
I tried downloading Java through IE, and I got "The installer cannot proceed with the current internet connection settings."
I know i sound like a noob, but I don't know how to run Firefox in safe mode, or creating a new profile.
I'm guessing by Fx you mean firefox, I did reinstall it, though still not working.
EDIT: I ran firefox in safe mode, didn't work.
johngalt
You;ll want to get familiar with this site: Firefox Support Home Page
How to create a new profile (read the whole thing, not just the creating a new profile stuff, as it is a good thorough walk through on how to trouble shoot Firefox issues): Basic Troubleshooting
Many profile related links (you should read them all): Mozilla Support
HTH
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
aukiman
just a note, I have heard of this specific behaviour if people have previously had Norton/Symantec products installed. Does this apply ?
Little free tool called 'EnumProcess' can probably help you identify whats stopping it working. You can find it by googling it.
johngalt
In that case either a reinstallation of the product and / or use of the Norton Removal tool should fix the issue.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Metalanca
I tried un installing norton, but when I try to uninstall it, I get "the specific module cannot be found"
When I try to download the Norton Removal tool, It won't connect to the download site.
johngalt
Use Internet Explorer to download the tool.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
sidewinder
Make sure that FireFox is not configured to use a proxy that is no longer available. Go to:
Tools --> Options... --> Advanced --> Network --> Settings...
And set it to "No Proxy".
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB)
    1 - Seagate Barracuda 7200.10 (500GB)
sidewinder
Okay. Look at the reverse. Check to see if IE is set to use a proxy....
S-
mocks1
I just signed up to thank member "aukiman" about the suggestion to uninstall Norton/Symantec products and it worked!
In my case--and my symptoms were,
I was getting the following message when trying to update Java from within Internet Explorer 8 (IE8) browser:
"the installer cannot proceed with the current internet connection settings"
Nothing was configured or checked under Proxy Setting in IE8 as I read to check for on other websites
Another symptom was that my Internet Explorer 8 connected to web pages fine but there were some noticible quirks trying to login to Yahoo Mail when entering username and password
Also, Firefox and Safari could no longer connect to ANY webpages and gave default/generic "connection could not be extablished" type message within the browser page
Once I uninstalled Norton Internet Security 2012 version--I was able to update Java from within Internet Explorer 8 and Firefox loads webpages normally again
Thanks again, "aukiman"--your hint was a push in the right direction--thanks for posting that hint and that is why I am posting my success to help others in the same situation
Uninstall your Internet Security/Firewall solution type product such as McAfee Internet Security, Trend Micro, Norton etc if you have same symptoms as I had above. You can always reinstall the Internet Protection/Firewall type software again later--make sure to note your install serial numbers before uninstalling and that you can first get a new program install file downloaded from the software maker's website too
