External Hard Drive doesn't show up in "my computer" but does in "device manager"
bp4131017
The hard drive is a Western Digital 320 GB that I've had plugged into this computer before (and worked). Then i got a virus and had to do a recovery of windows.
Ever since then I can't get windows to recognize/show it in my computer. I just "disabled" and "enabled" it in device manager to no effect. I have a C, D, and E drive which are: two partitions on the hard drive, and then the CD drive (respectively).
So i'm stuck, not sure where to proceed since it's obviously not the hard drive itself, I use it on my xbox all the time. What next?
patio
Vista Pro
Does it show in Disk Management ? ?
Right clik My Computer...select Manage...then Disk Management.
Find the drive...right clik it and select Properties.
Report back with your findings.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2
    Dos 6.2;Win2K;XP; &
    Vista Ultimate 64Bit.
bp4131017
where all the other ones have click-able boxes on the lower half of disk management: "disk 0" is there and reads"Basic", "230 GB", and "online" and is not click-able. It's just a silhouette (as is the CD-ROM drive)
patio
Vista Pro
Are you saying this drive shows up on other machines but not yours ? ?
    Intel Q6600
    ASUS P5K MBoard.
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    Dos 6.2;Win2K;XP; &
bp4131017
here's the screen shot... so clearly the computer see's the hard drive and recognizes it, but simply won't show it in my computer
SIW2
I assume that did the trick?
Glad it's working for you.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
bp4131017
ha, so that got it to work with the computer... but now it's not working for the xbox! What would i do to restore it to original format to work on the xbox?
SIW2
LOL,
That's tricky - is your xbox expecting a FAT formatted drive?
I don't have an xbox - but I expect it should be fine with a regular 0x07 partitions.
Just do the same in reverse - rt click it Modify>Change partition id , select OC , Yes, Apply.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
bp4131017
Yeah! It works on the computer, but now when i go to plug it in to the Xbox to play video show's i have on there... it doesn't work on the xbox.
What partition ID might it need to be in order to work on the Xbox 360?
MeR247
I know this thread is old but I just wanted to say THANK YOU to SIW2... I downloaded the minitool partition wizard and it worked perfectly!
SIW2
You're welcome - happy it worked for you:D
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
Anthonyd
If anyone else is still using Vista these days, get the same issue and land on this page (just like I did yesterday), I'd like to share the solution I found. (I don't like to install things I don't know anything about).
This is related to another old topic here ;"Vista "forgets" USB Device Locations" and displays the error <%3 NULL:OpText>
It's actually very simple, just uninstall the pilot (in the Properties of the USB device in the window that pops up when you're about the disconnect the USB).
turn you pc off, unplug the usb. Then reboot and when it's all ready, plug the USB device and let it find and install the pilot again.
woohoo it works!
That's it - this is the post I would have been grateful to read one day ago :)
