External hard drive
marija
Hi everyone,
I have a problem with opening and transfering files from hp pocket media drive(320 gb) to my computer (Vista home premium 64, HP Pavilion dv 7).
All the files are compressed (zipped) and I don't know how to open them and transfer them back on my computer.
I also don't have a lot of experience with computers.
Thank you!
I hope someone has patience to help me!:D
Hello marija and welcome to the forums :party:
Are these files from windows backup? For example, if they were they would be called Backup_set1 or something like that with backup in the name and numbered in ascending order.
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Yes they are.
It says back up files and when you click on it the numbers are in order,but I dont know how to open them and even see what it is!
Ps. Thank you!
Its very frustrating when you dont know what to do.
Also,there are 2 other files besides backup (marija pc and documentation) that I cant open.
Ok, and you are using Vista Home Premium?
Do you want to restore all of the files/folders or some of them?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Yes,Im using Vista Home Premium and would like to restore everything.
I already copied all the files to my desktop,but nothing happend.
What do you think I should do?
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hey Tom,
Thanks a lot for your advice.
I did the whole thing and none of my pictures or documents are back:confused:
I dont think I did anything wrong and I know those files still exist.
What should I do next?
Here is some additional information about restoring that may assist you if the above didn't work:
Here's an article on how to use Advanced Restore (when normal restore doesn't work): http://www.mayankraichura.com/post/2009/08/06/Avdvanced-Restore-via-Windows-Vista-Backup-and-Restore-Center.aspx.
Restore files from a backup
http://windows.microsoft.com/en-US/windows-vista/Restore-files-from-a-backup
Back up and restore: frequently asked questions
http://windows.microsoft.com/en-US/windows-vista/Back-up-and-restore-frequently-asked-questions
I hope one of these helps you restore your backup. If not, post back and we'll try to find some other solutions.
Good luck!
    1920 x 1200 pixels
